Grim Reaper
I'm taking a stabbing guess here because I have never seen the inside of a manual transmission...but...
I've been driving with a whacked out synchro now for about 2 months and it always grinds into 2nd. I'm sure 2nd gear is gonna have some kind of damage to it. Does a basic rebuild include new gears too?
Its bearings. The bearings wear out and allow the shaft to walk forward. For the syncro to work it needs to be tight otherwise the gear meshing into it does not put enough drag onto the gear to match speed.
Wow the prices really came up since I did my W58. Bearing kit, gaskets and syncros( that I didn't need after learning about end play) was around $220. Bought a 12 ton press and a set of gear pullers from Harbor Freight. SO the total was around $380 including the tools. :smiley_drive:
What to do to help prevent this DO NOT LET IT RUN LOW. the front input bearings are above the fluid level If it runs low not enough oil get slung up from the lower gears to keep it lubed. High engine RPM aggravates the issue. Gear the truck to near factory so you are not having to drive in 4th on the hwy at 3500RPM.
