Nice Holes in your hood.
PhulesAU
Andrew Walcker said:
Nicely done, I got to give you credit as I would be way too much of a wimp to cut into my hood!
All I will say is" you couldn't hear any noise I made" over the sound of the DeWalt. That's my story and I'm sticking to it.
RunninRubicon
Hood vents
How much more noisey is the noise from your motor now. I curtainly have heat-shield with sound deadening on the underside of my hood to keep the whine of my supercharger down to a roar. I guess I'd have to sacrifice that though.
roadkill
robert j. yates said:
I have been considering ideas on how to reduce the heat generated by my AC condensor which I now consider to be the prime culprit in only getting a 10* temperature drop across my radiator.
Typical would be a 20* and I only have half of that which says to me that there is a reserve issue going on.
Robert, look on the back of the cabs of semis that are running an APU to reduce engine idling while maintaining cab comfort. there will be a about an 18"x18" condensor with an electric fan on it. you could modify your ac lines to plug into one of these and mount it under the TJ, across the radiator support bars under the hood or anywhere else you can imagine. jerking out that factory condensor and running one of these should help
Thanx.....we are considering relocating it or at the very least, seeing if we can get some more space and maybe a slim line electric fan in there too. Not much room.....
YaRiteZ71
