** No Longer Available. **
WITHDRAWN
2011 Northstar TC650 Pop-Up Truck Camper
Will fit any full size, 1/2 ton and up, 5.5ft - 6.5 ft short bed truck.
Options:
95W solar panel
TorkLift GlowStep Stairs
Half wrap-around rear end with LED tail lights
Extended cabover with full size queen bed (60x80)(north-south)
Exterior Side Lockable Storage
Water heater with exterior shower, bypass and water pump
Gray water holding tank
Large assist handle
Overhead Storage Cabinate
Lagun Table Support System
Standard Equipment:
Dometic 3.7 cu/ft 3-Way Refrigerator
16,000 BTU Auto Ignition Furnace
Pre-wire for rear AC
Slider Galley Window with Screen
4-Corner Mechanical Jacks
Screened Entrance Door w/Deadbolt
2 Burner Stove
Lift-Up Cabover Bed w/2 Gas Struts
Single Sink w/12v Mini Pump
30 Gallon Fresh Water Tank
Front Rubber Bumpers
City Water Inlet
Marine Grade Ultra Light Plywood Construction
Exterior Rear Lockable Wing Doors
30 AMP Power Cord w/Adaptor
Interior & Exterior 110v Outlets
25 AMP Converter
12v Utility Receptacle
LPG, Carbon Monoxide, and Smoke Detectors
Fantastic Fan w/Thermostat
20 lb Laydown LP Tank
2 Interior Fluorescent Lights
$11,500 OBO
located in Albuquerque, NM
You can read more about it:
http://www.expeditionportal.com/forum/threads/94707-Ford-F250-amp-Northstar-TC650
WITHDRAWN
Options:
95W solar panel
Large assist handle
Standard Equipment:
2 Burner Stove
City Water Inlet
25 AMP Converter
$11,500 OBO
