Off road Tear Drop
timlaw71
I recently bought a used 2012 Little Guy Silver Shadow. I bought the trailer for a price I couldn't refuse so I decided to put a lift, new rims and tires on it. I then added some ax and shovel mounts and then a 5 gallon gas holder. Once the roof rack went on and the yak holder and ARB awning was mounted it really brought this trailer together. I love how it looks.
biskit
How do you find the suspension? how much weight do you carry? and does the trailer bounce much. It's just that I have that same suspension with not a lot of weight on, and it does seem a bit stiff. Nice looking teardrop :drool:
timlaw71
Id like to know how they vent the ac and drain
There is a void between the cabin and galley. Most of the moisture evaporates but there is a drain that runs to the bottom of the trailer. The cowls on the side are the heat vents for the exhaust and there is a fan in the void that moves the air out. Also under the trailer is an intake vent for the ac.
timlaw71
The trailer is around 1200 lbs I believe. I carry a little on the tongue but no too much. The trailer bounces a little but I also need to lower the tire psi (it might help). It doesn't feel too stiff though.
slowseconds
Old post, I know, but any info on what size tires are in the pics? I'm planning to install the Dexter #9 lift kit on my 2016 Silver Shadow, and trying to see how big I can go if I also upgrade to 15 inch wheels.
WonaWarrior
