I have been researching various trailer builds and while there seems to be some "rules" some builds seem to defy generally accepted practices.
For example, having the tounge level to the tow vehicle. Having the width of the wheels of the ideal trailer matching that of the tow vehicle is another "rule". The bigger the wheels the better. For off road trailers some advocate the use of shocks, some say springs only. And, there was something about the length from the hitch to the center of the wheel being related to the length of the wheel base of the tow vehicle. I didn't find too much about the heighth of the trailer other than it should not exceed the height of the tow vehicle, but looking at any travel trailer towed my most SUVs seems this is a suggestion.
Most of the off road trailers I have seen pictures of have the frames set high above the center of the wheels. Most have solid axels running across at the center of the hubs. Obviously the axel must clear any obstacle along a trail so anything just above the axel should be clearing as well. The only advantage I see to going higher is increasing the departure angle.
But putting the frame high above the axel seems to limit the size or height of the storage capacity of the trailer if the overall height should not exceed the height of the tow vehicle. At some point, it appears that a taller trailer will be prone to roll overs. And, the cure for a top heavy trailer is to widen the wheels, but then they may no longer follow the track of the tow vehicle.
Are these issues consistant with how you design a trailer? What are the basically accepted rules to follow to build a great off road trailer? What should you strive for?
