Androvers
Hello, so on my 94' 3.0 Liter my power steering oil pump pulley belt requires tightening and the two holes in the pulley that allow access to the bolts must be in the right spot to access them, what's the best way to line this up? Also there is a single wire coming off the side of the oil pump, anyone know what this does? Last question, there are supposed to be three bolts that need to be lossened to adjust the power steering oil pump and thus the tension on the belt, my pump is missing the bolt on the rear of the pump, any ideas as to the size/type of bolt I need to buy to replace the missing bolt? Thank you.
