NorCal1P10
I would like to set up a pulley system in my garage to lift my camper shell from my pickup truck. My shell weighs approx. 200 lbs. Problem is, my home uses trusses instead of conventional framing for the roof. I've heard conflicting answers on whether a truss system would be damaged while supporting a camper shell.
My basic design would be a two seperate 2x10's (spaced several feet apart for the front and rear of the shell) layed perpendicular across several trusses in the attic. Attached to this would be four threaded rods that would go through the sheetrock on the garage ceiling. The threaded stock would again go through a similar 2x10 setup pressed against the sheetrock and held in place with washers and nuts on both ends. So, in essence, the 2x10's would be sandwiching the trusses from above and below to spread the load. I would then attach some sort of pulley system into the 2x10's for a solid anchor point.
Any comments or concerns with hanging a camper shell from a truss roof system? I think it is doable but I definitely do not want to cause any damage to my home. I would like to keep my camper shell stored on the pulley system while I travel with my Northstar truck camper, but if this idea is questionable I would at least like to use the truss system to lift the shell off before lowering it down onto a cart for storage elsewhere.
Thanks for your answers,
1P10
1P10
