Old Man Emu OME Nitrocharger Suspension Tacoma 4Runner FJ Cruiser
tjalward
I have several sets / pairs of ARB Old Man Emu (OME) Nitrocharger shocks and struts for sale.
#1:
Old Man Emu OME original nitrocharger front strut pair. These are not the newest "sport" generation, but the softer "original" generation N140S models for the front of 2005-up Toyota Tacoma. Were very popular prior to being replaced by the nitrochager sport series shocks, which are high pressure gas and stiffer. Lots of fellas still prefer the N140S for its softer plusher ride. Especially if your truck is does not have any added front weight, or a single cab (lighter than double cab obviously). Bought used, never installed so I don't have any direct experience. Was told less than 30K miles, and the oil seems really good and it feels great when I cycle them. Seems like they would be great for someone that does mild offroading with mainly on road travel. Comes with spring seats, and OME trim packer for drivers side. Shafts look perfect. No leaks. Stud threads are good, some minor wear on the side of the unthreaded portion of the stud, where the rubber or washers or top hat was rubbing. Not a concern, won't impact operation or reliability in any way. Minor rock chips from normal use. Couple these with the 884 or 885 springs and you would be good to go. Looks like the places that still have them left are getting about $150 each for these.
https://www.sierraexpeditions.com/index.php?l=product_detail&p=1563
Asking $80 for the pair.
#2: SOLD
Old Man Emu OME nitrocharger sport front strut pair. These are OME part number 90010. Comes with trim packer for drivers side. Intended to be direct bolt on for 2010+ 4runner and 2010+ FJ cruiser. I was told the valving is identical to the Tacoma part number, with the only difference being the width of the eyelet on the bottom, where the lower control arm attaches. This is 0.080" wider eyelet in the 2010 + 4Runner and FJ's compared to the same Year Tacoma. Simply grind down the outer edges until it fits in the Tacoma LCA and you have the same shocks as what is meant for Tacoma. Or of course maybe you have or know someone with a 4 runner or FJ that would use these directly. Stud, shaft, bushing and everything about these is perfect with the exception of the rock chips in the paint which caused some minor rusting of the surface. These were installed and used for 15K miles before the owner of the 4runner upgraded to ICON. Would work great with OME 884, 885, 886, or 887 coils depending on your lift goals and added weight. The oil seems really good and clean and it feels great when I cycle them. Looks like about $330 online price.
https://wheelersoffroad.com/product...ome-90010-nitrocharger-sport-front-shock-set/
Asking $SOLD for the pair
#3:
Old Man Emu OME nitrocharger sport rear shocks pair. Part number 60020. This is the match to the nitrocharger sport front struts above. Intended for the '90-'95 4Runner, and 80 series Land Cruiser. Also used for 03-09 4Runner and 07-09 FJ Cruiser with 2" rear lift springs. Extended length from center of eyelet to base of stud (where all stud top shocks should be measured) is 24 3/8". Compressed measurement is 14 3/4" for ~9.5" stroke. Very good condition, shafts are perfect, bushing perfect, oil feels perfect when cycling by hand. There is some black overspray from some undercoating, will wipe off. Minor chips in paint from stones no big deal. Could be mounted on Tacoma with only changing out the lower bushing to account for the smaller diameter bolts used on Tacoma. Looks like they go for over $200
http://toyteclifts.3dcartstores.com/Rear-OME-60020-new-sport-shocks-FJ-03-09-4Run_p_214.html
asking $80 for the pair
#4:
I will also be selling the completeOld Man Emu OME Nitrocharger sport shock system that is currently on my Tacoma. Extremely good condition and only about 8,000 miles on it total. If you want to go for a test drive and see how they feel I can do that. Will be coming off the truck in a month or so. A deposit will hold the setup for you when it is removed.
Front:
This is part number 90000 for the front struts, with trim packer, springs #885 for ~2" lift with medium load, fully assembled with top hats and top plate spacers for additional 1/2" lift. Works really well. Happy with this suspension package, but I am getting a steel front bumper, winch, and a bunch of other front weight. Just acquired the new OME BP-51 suspension system that I will be using.
https://wheelersoffroad.com/product/toyota/4runner- show contact info -2009-4runner/suspension-229844/old-man-emu-205552/old-man-emu-2885-front-coil-set/
https://wheelersoffroad.com/product/toyota/4runner- show contact info -2009-4runner/suspension-229844/old-man-emu-205552/old-man-emu-90000-nitrocharger-sport-front-strut-set/
https://wheelersoffroad.com/product/toyota/4runner- show contact info -2002-4runner/suspension-437513/old-man-emu/old-man-emu-95pf5-trim-packer/
Rear:
This is part number 60091. Rear shocks for Tacoma. Worked great for my Dakar leaves, good suspension feel. Will work for lift 0-3". Very good condition, no issues whatsoever. Selling because of pending updgrade to BP-51 suspension.
https://wheelersoffroad.com/product...-emu-60091-nitrocharger-sport-rear-shock-set/
Can discuss price with anyone interested. Obviously can't sell till I get them off. Will update with pictures later. Thinking of asking $400 for it all?
Please contact me by email or PM. Please ask any general questions with a reply to this thread so others can benefit as well.
Thanks
OME 90010 - SOLD
tjalward
They come with spring seats and a trim packer. The stem bushings will be part of your top hat assembly when you install your springs. Yes I can ship.
tjalward
OK, send me your zip code for a shipping quote, then we can get the payment done through PayPal. Can I interest you in the matching rear shocks 60020? package deal...
WonaWarrior
