OldManTan 1st Gen Sequioa
OldManTanSequoia
There aren't a ton of us around and I have a bad habit of udating these kinds of things, but I figured I'd at least get the basics rounded out since we've had the truck 4 years now.
2002 Toyota Sequoia SR5 4x4 (leather interior, no sunroof)
Exterior
BruteForceFab (BFF) front bumper
BFF Kickout Rock Sliders (welded)
BFF rear bumper with modified single swingarm
-10lb propane mount​
-Fold Down Table​
-2x 5gal rotopax​
-spare tire carrier​
Skid Row
-Front Skid​
-Oil Skid​
-Transmission Skid​
Full Length Fuel Skid Plate
Trimmed Front Fenders and factory arches
100 Series Snorkel
OCD Roof Rack
ARB Front lights
RC Front and rear bumper square LED Lights
Custom LED headlight Retrofit
Interior
Exterior Light controller mounted in upper console
RamMounts Phone Holder on driver grab handle
RamMounts iPad mount
Midlands MX575 GMRS
BRO seat panel
BRO Wife storage
2x interior fire extinguishers
middle and rear seat delete
Raingler Attic Mesh Storage
Raingler Rear Barrier Mesh
Custom Aux power:
-100aH LiPO4 battery​
-50a DC-DC charger​
-2000W Inverter​
-Bluetooth Controls​
-Aux lighting controls​
Dometic CFX75 Fridge
Custom rear drawer system
Suspension
SoloMotorsports 14" Long Travel (strapped to 13" currently)
DuroBump Stops
Swapped to 04+ Gusseted Spindles
Polybushed Steering Rack
333 Fab rack clamp
80 series Dobinson 6" MMR Rear Shocks
200 series Ironman 4x4 rear springs
Timbren Rear Bump Stops
Wheels/Tires/Brakes
17x8.5 -6 Weds Hase Spec 2
37x12.5 R17 Yokohama X-MT
ARP Extended Wheel studs
GX460 Front Brake Conversion
High Carbon Rotors
Hawks LTS Pads
Drivetrain
CDL Switch Mod
ARB twin compressor
ARB Front Air Locker
ARB Rear Air Locker
Nitro 4.88 gears
ECG sleeve
ECG pinion collars
Modified CV Axles for angle
Recovery/First Aid
Smittybilt XR3 12k Synthetic Winch
Factor55:
Faltlink E​
Soft Shackles x 3​
Fairlead 1.0​
Treesaver​
30' Tow Strap​
RRP​
Shorty Strap x 2​
MyMedic:
MyFak Large​
MyFak​
Sidekick​
Engine
150a alternator upgrade (upgraded lead wire as well)
Replaced all rotating assembly minus water pump and power steering pump
Custom oil catch can
New OE Starter
New Denso Radiator
New hoses
Extended differential, trans, t-case breather hoses
Extended headlight and corner light breather/vent ports
New OE Water outlet housing
New NGK Plugs
Motul RBF
Motul ATF (trans and P/S fluid)
Wishlist:
TC Heim LBJs w/double sheer outer tie rods
King Rear Shocks (11” travel)
Califab trailing arms
King bumps (front)
Renogy AI1 monitor
Simplify camp cooking
Install Solar Panels
T-Case HD Skid
Replace trailing arms brackets
Double sheer UCA
Modification has been made to the front firewall and rear wheel arches to properly fit and stuff the 37" tires. Not a straight bolt on.
I'm sure I've forgotten a good bit, but that's the jist of it. I've got a few repairs to make to the body over the last few years of travel for this years trips (broken passenger mirror, damaged driver door, and crushed rear hatch) along with some other maintenance.
I'll also post photos later tonight.
Kpack
Love the 1st gen Sequoias. High on my list to get and build. I really like what you've done so far with yours.
A couple of questions:
1.) How are you liking the 37's and 4.88 gears? I'm looking at upping to at least 35's on my 1G Tundra and am not opposed to 37's. But need to figure out what gearing to shoot for. Currently running stock 3.91 on 33's....runs fine but not a lot of torque. Was considering 4.56 for 35's but would be too low for 37's.
2.) How much modification did you make on the firewall for 37's?
3.) Liking the Solo long travel kit? Again considering moving up from mid travel to long travel. Any issues fitting on tight trails with the wide stance? Dedicated 4x4 trails in the NW are pretty tight.
4.) What tablet mount are you using?
WonaWarrior
