New to me 2002 Montero limited. When buying I tested the heater and it worked, but I only checked driver vent, because that's where I was sitting. Took it in for new timing belt, water pump, and today I noticed it blowing cold air out if all vents except driver side closest to window. Not sure if it was like this when I bought it, or air in the system from water pump change. I tried to bleed coolant system, but haven't had any luck. Could it be something else other than air in the system?
