Opinions on Block Heater replacement.. 400watt vs 1000 watt
roving1
Doesn't the idi have a heater in the fuel bowl?
Dunno...But I would insulate and heat the lines, filter/separator and rig it to a manual switch as an electrical off grid pre-heat source before I would try to heat the entire block and coolant with off grid electrical energy.
Fredricksen
There is a wire loop around the top of the fuel filter head.. (between the filter and the mount) that was designed to heat the fuel.. (in theory)
