What are you comparing this to? A 2006 will only have issues if you go screwing it up with a tuner. The common rail and fuel pump on those motors is much more forgiving than newer models.
Comes from owning a common rail Cummins (early 2004 305/555) for over 11 years...........I would not personally own a 04.5-07 Cummins. I would either find a 2003-2004 5.9L HO truck or find a 2007.5 6.7L truck.......IF A DIESEL IS NEEDED
2004.5-2007 trucks will always run hotter than 2003/2004 trucks (305/555)
The 5.9 Cummins is "the same" motor, but many internal differences
2003/2004 trucks did not have a converter also, and another reason why the EGTs were cooler, less restrictions
2003/2004: Holset HE341 Turbo; 54/58/9
2004.5-2007: Holset HE351 Turbo; 60/60/9
The electronic wastegates on these were also problematic
04.5-07 HE351:
7 blade 60mm/60/9
19mm wastegate hole non divided
__________________
2003-2004 trucks have an 8 hole nozzles
2004.5+ trucks have a 5 hole nozzle
Both trucks use a different piston bowl design also
555 motors (2003 and early 2004): 5.9 and 6.7 injector nozzles have a wide spray angle due to a reentrant bowl design.
600/610 motors (2004.5+) 5.9 injector nozzles have a narrow spray angle due to the open non-reentrant bowl design.
555 motor: 143* injector spray impacts annular region of 113* piston bowl, concentrating combustion towards the piston dome. 8 hole nozzles with two injection events
600/610-series: 124* injector spray impacts central region of 140* piston dome, propagating combustion towards the cylinder wall. 5 hole nozzles with three injection events
The 2004.5 trucks have a odd piston bowl design, 5 hole nozzles with a less efficient spray pattern..............all this, when coupled with the 3 injection events makes the motors MUCH MORE prone to piston melt downs and higher EGTs
In 2007.5, Cummins went back to the old 2003/20-04 piston bowl design for the 6.7L CTD motors
