Over heating!!!
David Harris
Did a search and came up blank. What's the easiest was to purge all the Air about of the cooling system? Something about geting the Truck on an Incline right???
thanks
Nate
Use the procedure in the factory service manual. Remove both the radiator plug and the coolant overflow cap. Fill the radiator as high as you can using the coolant tank. Start motor and run it until the thermostat opens. Top up coolant tank as needed. Replace plug/cap. Run it some and recheck coolant overflow tank. It's always worked well for me without having to incline the truck.
David
flipstick
