Overland Journal: 1995 Range Rover Classic
getlost4x4
I love Range Rover. Just sold a 94' LWB with 108K on the ticker. Not as nice as that one though.
Mack73
I'd love to get my hands on a '95. But the only thing that scares me is the availability of parts.... like the front windshield.
proper4wd
One of my favorite looks for these is an ARB bumper while retaining the air dam with fog lights. It's not practical for four wheeling but looks great and does the trick for deer strikes.
And new mudflaps for it all around! Bonus points for converting back to EAS.
Christian P.
Staff member
Nice choice Scott. The very first time I went to work in Mali, our local coordinator had one in his garage (SWB I believe). it was all packed and ready to head out at any moment in case we had to leave in an emergency.
I guess I could see myself owning one of these...
TexasTJ
Climbing Nerd
Thanks guys.
A few more images from the trip home.
The VLA. Impressive in person
Soctt the next time you drive by the VLA you need to check out the Enchanted Tower. Its a really amazing climbing area just about 5 miles west of Datil, NM. The Tower is one of the coolest Rock formation in the lower 46 and the Forest road that services it is a nice mild drive too. Just love me to New Mexico!
by the way the Rangie is beautiful too.
Sahararover
I owned a '93 Ardennes Green SWB RRC, a sofa on wheels...it's great in stock condition but it definitely needs a rear diff beef up.
I don't know if a rear True Track is going to work correctly with the viscous center diff...
Scott Brady
Founder
Thanks guys. Starting to collect some restoration pieces now and deciding on a new set of tires (most urgent).
The TruTrack will work ok with the viscous center. It will also compliment the factory rear traction control. The rear axle needs a new pinion seal anyways, so might as well give the whole axle some love, including a traction aid. No intentions of using this vehicle for rough stuff, so a simple LSD will be a nice addition.
voyagenland
I confirm,a rear true track work really ok with the viscous center.very surprising where you can go with good tires!!
i got one on my classic.very smooth!
David Harris
Scott, for the springs to raise the suspension back to the original Range Rover Classic height, with mild loads in mind, try the factory rally specification springs, as used in the Paris-Dakar trucks. The part numbers are NRC 2119 (green stripe) for the front and NRC 4304 (red/white stripe) for the rear. I have used these on two of my Rangies and they are the perfect all around springs. Great flex and handling without sway bars but not too stiff as to ruin the proper Range Rover feel. Old Man Emu and such are great for heavy expedition loads but so stiff as to defeat the concept of the Range Rover in my opinion.
Scott Brady
Founder
Very cool insights. As I understand it, the Range Rover was lowered about 2" over earlier models in the late 80s or early 90s. When you look at the early trucks, no doubt they had more clearance from the factory. I like the idea of genuine (but taller and slightly stiffer) springs and shocks. Stick with the 215/85 and possibly install a trutrac in the rear. That will be about perfect.
Speaking of perfect. . .
guapstyle
