Waytec
I am I crazy or what
So I am piecing together parts for my overland Daly Driver. a 88 and up Comanche. I say and up because the mint body is a 88 but everything ells is going to be from "and up" I currently I DD a 90 MJ.
The plan is to take the Trans. t-case and front axle out of the 90 and put it in the 88. The 88 is a 4 banger, 2WD with the simplest dashes. So all the electrical is going be coming with the engine including the gages. I also have a Chrysler 8.25 to replace the D35.
For Overlanding I have a cap that came with the 88. so gear will go under. Both rear bumpers are pretty beat so I am thinking of building a custom off road/swing out tire carrier.
For the front I am going to keep it stock, adding recovery hooks. (If I ever do put a winch on it I will fab up a hidden set up only showing the fairlead.) I also picked up the MJ bush guard. Yes the MJ one. most people went with the XJ one because it was more than half the price of the MJ one but this is the MJ one.
Eventually I will lift it to about 4 inch. and put 33's under it. with 4:10 gearing. also For paint I am thinking of Land Rover G4 Orange.
So am I nuts for thinking of doing up a MJ. I am just getting a little skittish right now because the parts are starting to accumulate and thins is the time to cut and run or dive in.
