Overland Trailer - Lowe’s 3x5 Carry On - Kevin
jenren81
looking good! what width did you end up going with for the replacement axle? i have the same trailer and am about to order a new axle with about the same size wheels and tires.
I think it was 59”? I’ll have to verify...
The width is dependant on the wheel offset you want to use. I needed a very wide axle because I am using wheels with a 48 positive offset, and no adapters.
James
jenren81
Same here with my wheels, no adapters and a positive offset... my trailer is actually the 4 foot wide version so adding 12 inches to your axle puts me right where I calculated with my numbers and measurements so that is good :). Thanks for letting me know!
Couldn’t wait any longer, had to mock it up and see how everything looked. Still working on paint, but the top section is finished.
These first few pics are with it packed light.
James
509051509052509053509054
2 things happened today.
1) Took a test drive down the road and back, including over railroad tracks, and down a washboard dirt road with potholes about 6” deep.
2) Deployed the Tepui roof top tent on the trailer, so we could get an idea of how it would work out in the wild.
The potholed dirt road yielded two unexpected results:
1) The trailer pulled wonderfully, riding smooth, not making noise.
2) A bent fender mount, which happened because the suspension traveled too far, forcing the tire into the bracket (in one of the potholes no doubt).
Further measuring and troubleshooting revealed bent leaf springs.
*In an effort to soften the ride I remove 2 out of 3 leaf springs from the spring packs. Apparently my math was a little off, and the weight was too much for only one spring.
So, Monday/Tuesday I will install new leaf springs and retest.
James
quigleyth
