unkamonkey
A lot of the times, I do liquid electrical tape, shrink tube and another few coats of the liquid electrical tape. I havent had a failure yet.
No need to cut a hole for the pump. It's right there in front of the tank. Take a look behind your differential. 97+ you have to drop the tank
If anyone knows about a parts MJ Comanche with the console I'm looking for, I'd sure appreciate it!
This is also the time to consider placement of anchors for your eventual sleeping platform.
I don't think that small console is limited to MJs. There were XJs made with the same sort of console design. Had one small console up front for the shifter and then another midget console for the e-brake. No heat provision for the back seat passengers. I have seen them in the junkyard. Should be easier to come by than the pedal style e-brake.
After I find the parts, this is going in between my seats. This is the Dometic CDF-11 console Fridge/Freezer. I think it'll nestle in there nicely!
I think you might be right about some early XJ's have the short console, but the entire reason for the conversion to the Pedal E-Brake setup is so that I can mount the Dometic CDF-11 in between the front seats, right where the E-Brake handle currently is.
There is exactly 9in between the front seats and the Dometic CDF-11 is exactly 9in wide!
Just make sure that the venting on the fridge can breath. Had mine error out once (just shuts off) due to me inadvertently blocking the side vents (a sleeping bag and pillow moved in transit). Just something to be aware of if you're trying to cram it in between the seats.
