Overlandtowater’s solid axle suburban
Overlandtowater
I'm in the process of converting a 14 bolt full floater to 6 lug. It's been challenging.
this semi floater is really pretty strait forwards I just need to look at the 10 bolt under the truck to see exactly how the plate needs to be clocked. the hardest part is going to be cutting all the leaf spring brackets off to weld on my link brackets, I could convert it over to leaf springs I have a set of 2500 springs already, but I think my current setup will out flex the leafs.
pappawheely
Autonomous4X4
Cutting is easy. If you cut too little, it just takes longer. If you cut too much, you compromise the axle tubes.
Overlandtowater
A little more done. Finished pulling the backing plate brackets off the 10 bolt and reamed them out to slide on the 9.5 housing also cleaned up the 9.5 tubes to get ready to weld the brackets on. It is a little pitted up where the u joint plates were.9E530DC3-48CC-4070-A56D-5F104B837497.jpeg751C892D-0880-4BEF-BA1A-4875EDC83E2A.jpegF1548C3E-DE5D-4FDF-B4B8-99EBB37A57E1.jpeg
Overlandtowater
Got the brake baking plate mounts and some of the brackets welded to the axle. Yes newer Tahoes and suburbans come with this axle already, kinda. The newer ones have smaller wheel bearings than this axle and the 4.10 ring and pinion from the 3/4 ton axle I have will not swap over the pinion is smaller on the newer ones. EC062954-EA8A-4595-998F-650566D6A2D1.jpeg
Overlandtowater
Not much this weekend tacked the track bar bracket on. Waiting on parts for Barnes 4wd before I finish welding it up. Gm 9.5 diff cover from undercover fabworks came in and I smoothed the lower portion of the housing down, took a 3/8” lip off the bottom. Also received my diff rebuild kit from Timken5ADC6A36-B04D-4DED-9244-8C3DF689603E.jpegDCC4AA68-0238-47D2-B7F2-84C015BA8FEB.jpeg2F6A130E-35FE-442A-A011-864025713072.jpegE575669D-A9C0-42A5-9862-A1BFF5CAE4A8.jpeg6C5794BB-AD6E-48EB-9287-915E41B789C6.jpeg.
Overlandtowater
A little more progress. Part’s finally came from Barnes, I got the coil mounts and the bump pads welded on. Fully welded the track bar bracket on and boxed the upper link brackets. I plan to trim the lower a little bit a box it also. F0674D11-9E59-4866-8681-6D13A08D2E20.jpeg811680AA-0944-4B1D-A89A-B412E915B7DC.jpeg04F99B99-6E35-486D-95DE-C627EBE62D61.jpeg65FA955B-25F2-458E-925E-905BB17A9E51.jpegC86511BD-7B60-4B29-8A58-4997AD9175C4.jpegE8721EC1-5768-4764-8690-DD1A6B9ECCD5.jpeg0A3D941D-981F-4B24-8E44-7F115D2C497B.jpeg
Overlandtowater
The winch I decided to go with is the @openroad4wd winch13k lb. I tested fitted it and I will need to relocate the control box, I did this while I was thinking about the gears I was setting up and waiting for someone to guide me on the interwebs. From multiple people I should have just bought new gears and started fresh, but as a single income family of 5 I have to take calculated risks on some parts. The patterns are a little wonky because they are used gears but after 7 tries with the pinion shims I figured out I was going the wrong direction. This is the pattern that fit the acceptable category it’s centered between the root and the face and covers almost the whole tooth from heel to toe without running off. We’ll see when I hit the road. 5E291E52-F9A6-45B8-BB23-FFFDE6E31241.jpeg552A6911-8270-448B-96E5-CFA94805B375.jpeg39C7B1B5-8AF4-4646-ADF0-5117E7CBEA31.jpeg95736C8F-44D6-4C6D-9222-8D41A4CC87F5.jpegC3C59664-0DD7-413B-99BA-A247FD7142DD.jpeg
V45W_Proto2.5
