Overlandtowater’s solid axle suburban
Overlandtowater
I got the knuckle off today amongst the many other things that needed to be done. It appears there was more damage to that knuckle than just the crack at the lower ball joint. First if you look at the steering arm it appears to be bent downward, the steering stop is a bit mangled, and it almost looks like the lower portion that cracked is also bent downward. That’s coincides with everywhere the paint has popped off. IMG_7386.jpegIMG_7387.jpegIMG_7388.jpegIMG_7389.jpeg
Overlandtowater
Not much has been going on lately with the burb just normal day to day driving. I have slowed down on the burb a little because of a new project. I will start a build thread on it soon. You can just see it poking up above the burb. Bigger and better things. 😂IMG_9052.jpeg
Chonker LMTV
