Big Daddy Chia
How well does the oztent do in colder weather. I froze my butt off this weekend and that was with being fully clothed a 30 degree sleeping bag and a comforter over that.
I assume the oztent is canvas?Hltoppr said:Were you in an OZtent?
As with all tents, they can get cold. The interior of an OZt is pretty big; even for the RV-2, so it may be difficult to heat with just your body. If you're on the ground, a good closed cell foam pad, or other insulating mat, can make all the difference in the world, as conduction from the ground is a big factor in getting cold.
I've only camped in my RV5 down to the low 40s so far, with no issues. If I were going to be in snow/cold environments I'd likely do a full closed cell foam floor, and a tent heater.
I do think the material of the Oztent does a much better job at retaining heat than a nylon tent would.
Hope that helps. I love my OzTent!
-H-
adventurebuddies said:FYI - an airbed doesn't count much for "off the ground" in cold weather becuse the air in the mattress will equalize to the ambient air temp and any insulation that's under you will be compressed by your body weight. So, if it's 25* out you're sleeping on 25* with no insulation. You will be cold.
adventurebuddies said:If you like the airbed, you can buy a foam topper at walmart for less than $20 that will enable you to sleep on an airbed with sheets/comforter down to the high 20s or low 30s.
