Google it Research
Master of Disaster
Hello, I'm running 2x 120 watt solar panels on a jeep trailer. The panels are wired through the charge controller to my battery. I've noticed that in mid-sun my voltmeter reads between 14.4-14.7 volts. By the evening my voltmeter reads 13.1 and at late-night/early morning the voltmeter reads 12.3v. Now, my question is do I have a parasitic leak or is the higher voltage reading due to the fact the panels are charging? I've mounted a battery disconnect to the negative terminal which I use to disconnect all electronics (floodlights, trailer lights, inverters). The only thing connected to the battery full time is my solar panels by-way of charge controller.
Thanks for your input-
