Pintle Vs. Standard ball Hitch what are your thoughts?
Buliwyf
Viking with a Hammer
Mine's actually a pintel-ball. 2" pictured, I have another pintel assembly with the big ball under the back seat. Just remember to move those 4 bolts a couple times during the winter.
I've never needed to weld a sharkfin under a pintel ball either. A nice perk.
honda250xtitan
I'm taking my trailer up north tomorrow...hope the ball hitch coupler doesn't cause a catastrophic failure when i hit those speed bumps in the gas station!!!
mep1811
Gentleman Adventurer
I have been using a pintle for 20 years . Now I no longer have a M416 with a rotating lunette ring I have a rotating pintle hook. Much cheaper set up than a a fancy off road hitch.
lacofdfireman
I don’t know maybe I’m totally wrong here but I think we tend to over think this entire hitch thing. I’m pretty sure that 98% of us don’t haul an off road trailer anywhere that a 2”ball wouldn’t work. I’ve been in some pretty off camber situations with a 2” ball to the point where if I had a max coupler that just let my trailer keep rotating it would have probably flipped. I think a properly adjusted 2” ball could work for pretty much all of us unless you are extreme rock crawling. I know some of us think we are super hard core off roadies but I’d be very surprised if a 2”ball wouldn’t work 98% of the time. Just my 2 cents. Im not sure where all these stories about a 2” ball system just coming apart comes from but I’m not finding the info to support that. I’m sure I’ll have some disagreements but I’m pretty convinced I’m right.
Buliwyf
Pintel is quicker to hitch up to as well. It does't take much goo to mess up ball hitches. I miss our pintels at work, everything is ball now.
SoDakSooner
My setup is similar to several above. can change out to any style I want. Was going to do up a 2" ball setup but honestly at this point I haven't felt the need to.trailer16.jpg
Buliwyf
Don't forget about this mod:
Or at least, don't jack knife the trailer, in reverse, offroad, backing up an off camper hill. (lolz)
KD2018
Question for you all, I am new to ball hitch vs pintle. I purchased a pintle hitch to pull my pop up camper. My pop up camper still has the ball coupler portion, I was told I can just put the pintle hitch in the coupler..but it seems like that isn't correct.
rnArmy
If you've got the pintle hitch on your tow vehicle, then you need a lunette ring on the trailer's tongue. The easiest way is if your trailer's tongue has a 2" receiver hitch at the end. Then all you need is a lunette ring to slide in there and call it done (pictured below and in post #40 above). Any competent metal fabrication or trailer shop should be able to put a 2" receiver tube on your trailer's tongue.
Lunette Ring: https://www.etrailer.com/Off-Road-Accessories/Tow-Ready/TR63045.html
They sell these combo pintle hitch/ball things (which I think look goofy, but whatever...):
https://www.etrailer.com/s.aspx?qry=pintle+hitch&furl=-pg-Pintle_Hitch-sf-Pintle_Hook_~_Ball_Combo
but if you're running the ball coupler on your trailer, there's no advantage to using one of these combo things vs. a regular ball hitch.
