wrcsixeight
If you are serious about using the alternator to recharge, I think you will be disappointed. Alternators can do bulk charging fairly well upto 80% state of charge if wired adequately, but that last 20% takes forever, no matter what charging source you use.
Seeing as how this thread is about "topping up" a battery, the alternator is an unwise choice. If you were to take specific gravity readings during recharge and had a baseline to compare it to. I believe at about the 12 hour mark you will be in the 95 to 97% range. If you were able to measure the current passing to the battery, you might find less than 10 amps.
Recharging or discharging a battery is not simple math, and alternators are not the magical instant battery chargers the general public believes them to be
Some other factors to think about is even if the alternator at idle speed is going to do much, and if so, how long will it be able to do it as it heats up.
Peukert cannot be ignored either
