Power Steps on a 90 Suburban?
drifter_r6
Do you have any (or does anyone else) have a close up photo of the motor and it mounted?
  • Do they bolt straight to the bottom of the sills with sheet metal screws?
  • And do the upper mounts use sheet metal screws also?
Pics 4 and 5 show the motor mounted to the pivoting arm. Pic4: 3 bolts (white area) secure the motor to the arm. The "circular" areas each house gears which rotate and retract/extend the arm for the steps.
Pic 2 and 3 shows the lower mounting bolts on the lower sill (pinch weld). I would not call these sheet metal screws, the bolts are 3/4". The upper mounting bolt can kinda be seen in pic 5. There are U-nuts which clip into the body (factory holes). Keep in mind this is mounting on a Ford F350. Dodges use a mount bracket that you need to rivet to the sill and then bolt the arm to the bracket. I'm pretty sure the Chevys are different.
I think you should start by downloading their install manuals and look at the diagrams, compare to what you see under the 'Burb.
EricU
...I think you should start by downloading their install manuals and look at the diagrams, compare to what you see under the 'Burb.
That is what I have been doing. The guys at Amp-Research have been very helpful so far.
I am going to start printing out the appropriate pages of the different mounting systems from the various kits and hopefully can find a close fit.
Eric.
Goldenbora
