Sitec
Although at this time our power seems ok (the 200hp OM366LA) I did inquire with a company in the UK about a power upgrade (about $4,000 for an injector pump upgrade to give up to 270hp).
Interesting you should say this VerMonsterRV. This is the other reason I went for a large engine (10.4 litres)... Mine is only at 220hp in standard form which is ok, and is enough to keep our truck at near highway speed. I figured that a large unstressed engine with plenty of room for more power if required is a better option than a smaller engine working hard having been 'tuned'. This is also why I love the hub reduction axles. Very heavy over engineered axles with good ground clearance that are good for 400-500 hp. The downside to this is that the larger MK SK cab, V6 or V8 engine, heavier chassis and axles etc make for a heavier build. Because I have this, I now have a 6m body, a 500lt water tank, 30kg of gas, and space for more stuff!!! The 8 tonne planned build will probably now end up nearer to 11 tonnes... Too heavy??... Watch this space!! Guess it really depends on where we plan to go... This is all stuff that needs to be considered Link_Cat in your build. It's very hard to 'know' what you want early on and lots buy a truck and then build to suit it. If you have a shed or large room, I would suggest you lay out some plans to scale... See what space you are happy with and then build from there. I was really lucky that I found a 4.2m wheelbase truck, and then later on found and bought the 6m body I have. We started with the truck, then planned a 5 or 5.5m box. The box I now have was for sale for about a year and I'd decided against it. 6 months later when we decided to turn our beds around and have 2 single mattress as we both like different comfort. Suddenly we needed 6 meters. The deal was done and this 6m body has formed our build. I've widened it, lowered the floor, reshaped the rear, but it gave me a good solid base to start from. Things that all need consideration are:- Compost or flush toilet... Chest or upright fridge... Bunk beds or double or twin... gas diesel or electric heat... Air Con... grey tank... black tank... (not a fan), leisure batteries and how many... solar... seating arangements... composite or steel frame... The list goes on. Decisions decisions.... Great fun though!!
