Pretty Ugly... 1835, The Build Begins
Madoxen
Managed to mark out and cut the top plate for the two rear pivot plates
The edges still need to be cleaned up on the mill but its there enough
This one actually sits much further back but i had to cut 50mm off the 45 degree rear angles to get it where it needed to be
Alloy
Am I seeing this right....it was tested it with the rectangular tube verticial but it's being built with the tube horizontal?
Madoxen
Hi Alloy it was tested the same as it will be built with the same size od tube etc in the final tests shown below in pic
The material used was of much lighter guage than the final build will be though.
Did this answer question or did i mis understand it?
Madoxen
Tube here looks to be vertical.
Tube here looks to be horizontal. Orienting vertically has more resiance to torsion.
Ahhh now i follow you the tube in moc set up was 75mm heigh x 50 wide
The tube i have used is 75 heigh x 125 wide.
The reason behind this is purly a max height V torsional stiffness v flex/sag resistance . See below for a comparison .
I could have tryed to save weight with the 100x50 x 6 tube but decided the height and bigger allowance left on stress with equal deflection was the way to go. She was made to carry alot more load than i will ever be putting on her.
Due to my chassis already being massivly heigh i could not really go for anything heigher than the 75 mm and keep under my goal height of 3.7mtr all in with an acceptavle amount of head room in the hab. As with everything in these builds it is all a compramise / give n take / pleasure n pain
Alloy
Hmmm....is the "mid-piont mm" with both tubes oriented with the 75mm wall being vertical or does it compare the 125mm vertical to 75mm vertical?
Madoxen
Hey. They are both with the tube at 75mm heigh if i flipped it to 125 h it would be significantly less deflection mid point mm. In the chart it states 1st measurment is H 2nd is W and 3rd is T.
Alloy
The 50% reduction in mid point deflection from the 75mm wide to 125mm wide is surprising considering there is 70% more weight. What is the span?
Madoxen
The span is 2.6 mtrs ish. I must say the numbers suprised me but i had two engineers look at them the one that did the maths for me and another just to check all drawings and numbers etc
Managed to get the 12mm plate cut today for the middle and rear pivot plates. Needs to be tidied up etc but getting there
Madoxen
Have managed to get some more work done on the pivot sections.
Middle section almost all done. On the lower plate i milled a 2mm deep 12mm wide slot for the 2 plates to slot into and hold in place at exact angle.
Middle and rear sections need to be flipped upside down and welded in place
Running the front 100mm od 75mm id pivots through the lathe
Middle and rear pivot ultrabush sat on its new home. Just need to fab the rest of the middle and rear lower housing setup
M24 bolt with the 2 outer sleaves over the rear pivot plates. The bottom ultrabush is just holding the 2 plates at the 93.3mm spacing the actual placement will be much lower/higher when its flipped right way up.
Front lathed pivot pin sat in place in the 12mm plate housing / still have a few more bolt holes to do.( the mill sufferd a massive problem dyring the boaring of the plate and i had to drill/cut out the rest and then die grind it to fit so not the best finish here but it worked
All the bolt holes in place . The 6 upper holes seems like over kill but i had to remove 4 rivets and every hole must be bolted where a rivet was removed
Next on list take the front pivot pins in place and then fab up new mounting set up for the air box and exhaust silencer as the pins push them out from the chassis byabout 60mm.
Madoxen
Ok a little progress that i find amusing the time to reward ratio feels good to get it done but when u look at it you think why did that take so long lol.
The newly re sized re fabbed air box mounts offsetting the box to clear the new front pivot while still allowing it to marrie up to the in and out ports
Exhaust box also stepped out for clearence and the lower mount reshaped to bolt lower down as its original location was right in the middle of the front pivot
The side wings for the subframe in place checking on diamentions for the vertical plate sits in correct place for the front pivots
Sitec
It's so true that the smallest things seem to take sooo long!! I've spent all weekend sanding, cleaning and sealing the exterior of our hab box and when I closed the workshop door last night, I felt like I had nothing to show for it! Keep going!
WonaWarrior
