Project Mini Hägglund
Made both bearing supports for the drive shaft:
Also started machining the first half of the drive shaft with the disc flange:
Finished machining the second part of the drive shaft:
Fit`s perfect:
Everything finished:
Bolted together:
On it`s place:
And picked up the steel that i need to finish it:
Dgurley2000
Dude, where did you learn to work the lathe? Don't tell me YouTube :) Those are some sweet parts you're manufacturing in your workshop. Is the poster helping keep you motivated?
I learned a few basic things at school. but i taught most myself and with some trial and error... :ylsmoke::Wow1:
Was a bit handicapped today:
Mocked everything up:
Finished welding and drilling:
Everything together and placed a belt:
Added some new style grease zerks:
Started building the sanding wheel mount:
Machined the shaft:
Mount:
Those excentric things will be used to tension the belt:
One side tacked together:
This is going to be a big ********, it already weights about 400 pounds with the motor ...
Started building the contact wheel mount:
On it`s place:
Stand mocked up:
First time standing on it`s own:
Welds:
Also upgraded the fuses, so i`m able to run the motor...
nick disjunkt
Yes i do. Why not? Everything is fine and according to the law... One of the advantages if your dad is an electrician...
probably a translation issue here. Presumably when you say fuses you mean an electrical overcurrent device (MCB). In the UK at least we haven't used fuses in domestic wiring for many decades.
good work as always steinez!
deadbeat son
From the sound of things, I assumed you either put in a larger fuse or a larger breaker without upgrading the rest of the circuit to handle the higher current. However, if your father is an electrician, I'm sure he knows what he is doing and the circuit is designed appropriately.
Carry on! :ylsmoke:
Petersmithinak
