Project Mini Hägglund
nick disjunkt
That doesn't suprise me, but as long as you don't abuse the cutters you can get them resharpened almost indefinately.
What's the next tool upgrade? maybe some sheet metal tools for doing some nice bodywork? a brake press? punch press?
The next tool i want to buy is a oxy/ace setup with a torch...
Yes, i'll build a sheetmetal brake and a bead roller when i start the bodywork. A press brake would come in handy too, but i just don't have enough room for it...
Made some mounts for my mills:
Ozarker
Pretty awsome undertaking! Great skills and a shop for the task! Very nice!
I haven't read the whole thread yet, but saw the mention of transfering power to the rear, not sure where your bearings fit in, but...
Years ago, I believe it was Fitapaldi racing in the Mexico GP he rean a VW (may have won, don't remember) but they mated up two VW engines using a doughnut, two very rubber small rings that were looped together and bolt to a plate for each engine. It took the jerky-ness out of two independent engines.....
probably use something similar for dragsters, and, in all these posts it's probably been mentioned that Land Rover has a snow utility vehicle using a power take-off I believe.
Looks like you have it well in hand, just thought I'd mention something but you probably are already aware of such stuff.
More pics..... :)
Power will be transfered by a driveshaft to the rear unit...
Got a Eisele cold saw, a VFD for the mill, one for the lathe and a 40" sheetmetal brake today. I just need to pick it up and find some room for it...
Bushcoat
one trail at a time
I wish you were here, I have quite a few old slightly damaged or too worn out snowmobile tracks I would donate to this AWESOME PROJECT! I keep them laying around to make mudflaps or walking paths over the grass.
blaz
Thanks for inspiring me to get out and do some cleaning, etc.
I also made a tailstock for my turntable.
Keep up the hard work. It helps the rest of us get out and do the same.
AeroNautiCal
Stein,
You really should visit The Garage Journal, here, as they will love what you're doing, as we do, and there's two amazing German guy's making gorgeous toolboxes, here.
I can't wait to see your new tools in action.
chilliwak
Wow:Wow1:really cool addition to the tool park Steinez! Is that a `Danfoss´ electronic control system I see for the saw? If so, you got your hands on some good quality Danish hardware for your saw. I can certainly see why you are exhilirated about your new purchase! Nice stuff, and pretty soon you will be able to build a space shuttle with all the equipment you have there. Cheers, Chilli.:)
Those are two Danfoss variable frequency drives and a LC-Filter. They`ll go on the mill and lathe...
Put the sheetmetal brake on it`s place today:
Finished up the saw:
Everything works:
At it`s place:
Then i started working on the Hägglund again. First i finished the front cv shafts:
What do you guys think about this joint? Should give me a lot more welding surface. Copied this from a guys who`s building pto shafts:
Then i started with the driveshaft to the rear car :
Fits:
Front part finished:
On it`s place:
Then i started fabricating the rear adapter:
Lynn
Have you considered changing the thread title from " Project Mini Hägglund " to "Project Mini Hägglund, or How To Build a World-Class Machine Shop on 10 Euro?"
I'm really impressed...
dhuss
