Project Mini Hägglund
The auto feed didn`t work, but i found the problem soon. Adjusted it and everything works like it`s supposed to:
Then i machined a improvised tool holder:
Finished:
First try:
The i fixed the broken hand knobs:
Finished:
BuckeyeBullet
Wow, you have a better-equipped shop than our Dampflok-Werkstatt (although a couple of our tools are slightly bigger). Inspiring work!
chilliwak
Nice addition to the shop Steinez. I thought you already had a lathe but I guess there is always room for upgrades.:ylsmoke: It must have been expensive:Wow1: to have the crane deliver the lathe, or did you get a bargain on that? Anyways I hope you have a good holiday season and that you enjoy some hard earned spare time. Have a good one, cheers Chilli....:)
bobDog
Maybe he built the crane and just hasn't had time to post pictures yet. :D
Sent from my LS670 using Tapatalk 2
I`ve been busy working on the lathe, so it`s a bit slow here...
First i made a quick change chuck holder:
Mounted a LED light:
Then i built a coolant system:
And a switch paneel:
Mounted a new chuck:
Mounted a quick change tool post:
Scraped in the compounds upper surface:
Finished:
Made a forward/off/reverse switch:
Installed digital readouts:
Ground the chuck:
And build a dividing head:
Now back to the Hägglund:
Started planning the hydraulics today:
Then i installed the pedals:
AeroNautiCal
Truly outstanding stuff!
I really respect how you've re-engineered your workshop, and I'm in awe at what you achieve and find it inspiring to see your ingenuity and skill in action.
Many thanks for sharing.
chilliwak
Excuse me Steinez, is there anything you cant build? I mean you build your own chuck, and you even have kick *** Danish technology in your pump system! you got it going on mate.....:)
Got most of the hydraulics today. The hoses:
Pump, filter and valve:
Tried the hoses:
They fit almost perfect...
Made a longer lever for it:
Turned the lever around 90° so it does left/right instead of back/forward:
Made a mount for it:
This is going to be new joint between both car`s:
chilliwak
Really cool :Wow1:looking set-up there for your hydraulics Steinez! I guess you must have seen some cool vehicles on your trip to Austria that gave you some inspiration for making the new connection between the 2 Håglund cars. Nice stuff....:)
Nope, no cool vehicles there...
Started mounting the hydraulic pump today. Had to mount the new pulley first:
Welded it in:
Dialed in the cone:
And turned it in the new one:
Finished:
dhuss
