1500 watt inverter install
Okay, so I deseperately wanted a inverter in the jeep full time with regular AC plugs and a USB port to charge things for a while now and I finally got the first half of it done today.
I wanted it under the dash because its cooler there than in the engine compartment, and its nearly-waterproof under the dash when you get rained on or splashed from below. I know everyone is like you are dumb for getting wet all the time, is there anyone else out there who doesnt mind getting rained on in the jeep here and there?
I also could use it for work - lights and chargers, and USB for the phones, and let's face it, overland expedition? AC all the wall. Who has time to find a DC plug for this that and the other thing. I grabbed a blade fuse, fuse block, and 12 feet of 4 gauge wire and some zip ties, to make it all neat for phase 1
Here is the 1500 watt continuous inverter. it has 3 plugs on it's face and a usb port. The thought is to wire the switch to cut it on to the dash and two plugs and the usb to the dash and the third one to under the hood somewhere in beyond the firewall or to the rear. It also has a LCD readout to let you know how you doing with your voltages and stuff.
Next up to start is the blade fuse, I grabbed a 100 amp one, so that it can blow quickly if something goes wrong - i might move up to 150 or 200, but ill run the numbers again and see how well the amp performance in real life scenarios, better safe than sorry because Pain Hertz.
Next up was the 4 gauge wire, that should contain the current. I got a red and black one at about 6 feet each. I ran the red/positive into the fuse block and out the other side.
Next i opened the top to make it easier to rewire the power switch at a later date. I didn't get to do this tonight. Hopefully tomorrow.
Next I pulled out the dash yet again. I pulled the fuses for the air bags. shucks i have to go put them back in!
Okay, shoved it behind the dash, doesn't quite fit. I am choosing to remove the vent extension to the passenger side heating duct. the part that connects to the central duct, i tamped it down and screwed into the frame to make it flat for now. Where is that hot air going to go!
Okay, cut a whole in the rubber grommit in the firewall and threaded it with both 4 gauge wires, bought it inside and wired up the inverter. I
disconnected the battery again at this point, for saftey.
I used 3m doublesided tape , after cleaning the firewall to stick the fuse box to the firewall and then zip tied a lot of these crazy additional wires. There is another fuse block for the amp - im rather partial to loud music.
Next up I closed the dash. It fits! My passenger might not have the best heat anymore, I never use the AC - but now I have power! I have heated seats, so I guess that makes up for it. Looks like a good fit! Who knows what I broke doing this. any guesses?
you can see the numbers running thru the vent. when closed up for now. would be nice to move the lcd panel somewhere onto the dash or maybe in the vent, if I can make it look stock.
Lets try it! Yup! Powers up a fluorescent AC work light perfectly without breaking a sweat. This is gonna be great for camping, overland adventures and working on the job. No more dual chargers scenarios.
Oh yeah! Usb port works good too, cell phone is charging! Better I tested with this than the g2 android I am switching too, and this will work for the Ipad that I planning to use for the overland expedition. Okay! I didn't burn things down. I guess part one was a success! Tomorrow I'll burn another day at this, and blow of a date with a sexy girl.
So tomorrow I will try to tackle cutting the dash and putting in a USB slot and 2 AC outlet slots and tie the power to the switch. I dont know what the downside yet of modifying the right side air duct is yet. Anyone care to venture a guess?
