propane fuel etc
During phase II exercises at work I use artillery shell simulators that use propane and O2 that ignite and make a loud "report" to simulate mortar attacks. I will have to get a picture of the tank. Its pretty small. I am guessing 5 to 7lbs, but it is the perfect size. I know the owner of the company so I'll give him a call and see where he sources his tanks.
Martyn said:
Manchester Tank is the largest produces of propane tanks in North America. You can find anything from 20 lb BBQ tanks to DOT approved tanks. http://www.mantank.com/
Manchester Tank is the manufacturer of the horizontal tank on my trailer. A new tank was quite spendy. I was fortunate to find mine used.
I use a 10# tank, which when I bought I thought that 10# (equal to 10 1# cannisters) would be enough propane for a full week of heavy usage. The biggest user of propane for me is the lantern. I used to go through a 1# cannister during winter nights. So I figured 7#'s for that plus 3#'s for stove and the heater.
That's what convinced me to get the 10# tank over the 5# tank. But from usage, it seems as though the larger the tank, the more efficient it is. It definitely lasts longer than the equivalent amount in 1# cannisters.
I camp out ~100 nights a year, equally spent throughout the year. And I fill up once during the summer and twice during the winter. A fill-up (10#) roughly costs me $10, whereas a 1# cannister goes for as much as $5 in remote locations. The cheapest I could ever get them for was $2.29 at Walmart.
Plus you can fill up the tank (per gallon) in remote areas, where propane usage is more common. In metropolitan areas (Socal) they charge you a per tank fill, meaning whether you top off or fill the whole tank, it's a flat rate charge, like $25 or something. So I usually fill up when I get to where ever I'm going.
This is my setup. A two-burner stove, a lantern, and a small heater.
Steve Curren said:
I have a small propane tank and I hope I figured out how to get the darned picture in teh response..
Looks good. Do you have any more pics of how you mounted it to your Chaser? I see a couple of Quick-Fists. What about the support it sits on? I want to do the same thing.
broc
I went to a metal fabricator and had two 10x10 "shelves" made that have a "lip" the same size as the frame . I drilled through the frame and attached the "shelf" to the frame and I have supports under it. I did indeed use the Quick Fists to secure it, the super large ones and the regular large ones I got from Sierra Expeditions. I have driven over rough country with it and the man behind me said the bottle didn't move at all. I got the propane bottles at Home Depot.
Hope this helps.
Josh, I'm no propane or propane accessories expert, but DO NOT use a vertical propane tank on it's side. If you a horizontal tank such as the Manchester's that have been shown. Another place to find a used small horizontal tank is the old VW campers like a Westy. - Brad
Great. Thanks for the reply, Brad.
That's bad news but I kinda' figured as much.
I'll need to figure something else out 'cause I doubt I can afford one of those horizontal jobs.. I think they're in the ballpark of $300+ unless one can stumble onto a used deal somehow.
Kind regards, Josh
Brad is correct, vertical propane tanks are not designed to be used horizontally and present a safety hazard if they are. The valves are designed to seal/release vapor, not liquid propane as will occur when filled vertical tanks are turned horizontally.
VW Westfalia campers are a good source for used horizontal tanks. You might look for businesses that restore VW campers to see if they will part with one for a reasonable price, or auto boneyards with an inventory of old VW stuff.
I carry a small box with various regulators, adaptors, tees, hoses, etc. so that I can configure my system as needed for stove, lanterns, etc. I also carry 6 small propane torch cannisters (more capacity than the "Coleman" size, same size thread) and adaptors so that I can use a cannister if my trailer mounted tank runs dry and refill them from my large propane tank at home. Sure beats paying $1.50-$5 each for stove cannisters.
nahuebsch
