R_Lefebvre
Ok, total newbie question here...
Two weeks ago I had the truck out on a pretty rough logging road. Well, it had degenerated into a river bed actually. It was the most technical thing I've been on to date. The surface was basically head sized to 12-16" sized field stones. Some of them wet.
I navigated around the biggest rocks. I put the tires on the 12" rocks. I was in low range locked. The truck has decent power, but it was still kinda hard to get it go over a 12" rock. I'd slowly ramp up the power, but then it would want to shoot forward once the wheel is over.
I ended up using my left foot on the brake lightly, and right foot on the gas. I found dragging the brakes a bit sometimes helped with traction, but it also helped control the truck so I didn't come down hard on the other side. I was taking it very easy, not wanting to brake anything.
Is this the right way to drive on this surface? I was mainly concerned about braking an axle or coming down on the rockers which don't have sliders yet.
What about when you're trying to get over something, and various wheels are "ratcheting" as they slip-grab-slip-grab. I'm not talking about hammering on the gas, just gingerly trying to get over something and sometimes the tires "ratchet" is the only way to describe it, sometimes they hop a bit while this is happening. Is this going to break an axle, or is going to be fine with my small tires? (31.5")
Also, what's the best way to cross a small ravine which has gouged a ditch across the road?
The area I'm driving in is full of logging roads that used to have heavy trucks and such, but once they finish logging and area, they quickly fall into disrepair. There are tons of ATV's in the area that use them, and the surface tends to suited to them. An ATV would have no trouble getting across these ditches, but the depth and steepness seemed like it would be impossible for my truck. I'd get hung up on the breakover, or the departure with the long tail of the D2. When I reached this obstacle, I turned around, not having a winch or anything yet.
Is there any trick to getting through something like that? I figure bridging ladders would help. This was too big to span the entire thing, but I've seen them used flatten out the bottoms of these ditches.
