Pyeatt Draw Trail (AZ) Nov, 18, 2006
Status
Not open for further replies.
ShottsCruisers
mcvickoffroad said:
Man, This is going to be fun to watch!! :lurk:
Comfortably, from the bypass ofcourse! :ylsmoke:
That's the one BYPASS I don't plan to do again. (ShaftEater) Goodtimes is on a mission to get the Toyota Boeing 767 owner to do it any how. For some reason, Brian's been the only person to get me to do things nobody else can. Damn. He's coming! :hehe:
goodtimes
Expedition Poseur
Like I said.......
-Spike-
By the way Brian....we're hoping you'll try to bypass the ShaftEater and climb right up the rock wall instead. I bet you could make it. The far right side of this pic:
Dennis (Alacran on some boards) in his white Cherocar has done it, along with several other Cherocars and a CJ- all with winches (some of them didn't drive away- worse driveshaft carnage than Shafteater will ever produce). I know of only one guy who has done it without any help, in a Nissan Frontier ('slightly' modded). I'm sure any decent buggy could do it. I'd try it if I had a winch, but I'd probably better wait for that and some stronger rear control arms I'm planning to make.
-Spike
crawler#976
OK, once past the "filter" as the ledge is called, is there an exit prior to the final obstical? Without a winch, I'm not gonna play on that...
-Spike-
The 'filter' is the name for the final obstacle, shown on page 6 in posts 53 and 54. That's the end of the trail. 'Shafteater' (as Shottz has named it) is the bypass for the ledge pictured on page 13 in post #129. The LandCruiser in that pic has just navigated 'Shafteater' (and incidentally was the only LC to navigate it without driveshaft damage that day, other than mine- which was repaired and moved up out of the way after it got eaten the last time I ran it).
Most people who don't plan on running the Filter exit the trail before Shafteater, at the last point the forest road crosses the creekbed. That forest road crossing marks the change between 'Lower' and 'Upper' Pyeatt Trail. After exiting Lower, you can follow the forest road a couple of hundred yards and park right above the Filter and watch the fun there.
I would personally rate Lower as a 3.5 on a 5 scale, with Upper being a 4-4.5, as it requires a winch.
-Spike
ShottsCruisers
-Spike
Your words painted a perfect picture of the story in my head. See ya there Spike!
crawler#976
FYI:
For those of ya who are camping tomorrow, keep an eye peeled after dark - the Leonid meteor shower is gonna be occuring! While we're not in a prime viewing location, there should still be more meteors than normal.
It's a also a new moon, so one ones you do see should be BRIGHT!
DaktariEd
2005, 2006 Tech Course Champion: Expedition Trophy
Actually the Leonids are not visible here in AZ.
It will be an East Coast show and maybe only for 30 minutes: Leonids
Sorry about that!
I had been looking forward to them, then discovered that Leo won't be visible...shoot!
ShottsCruisers
Well..I'm chasing a problem with my 100-series, but I'm bringing it any how. It's making a low-pitched "springy" type of vibration sound from the rear axle area when I hit a bump. It lasts for a second or so then is quiet.
We found my upper rear arm bushings were toast and my dude slapped new arms on yesterday. The sound's still there but he's unavailable.
I know he felt around under there already, though he stopped when he found the bad bushings. So, something else is still wrong.
I'll be at the meeting place at 9 AM if anybody who knows trucks could take a peek before the run. I'd sure appreciate it. If not...I'll count on Land Cruiser reliability to get me home. :088:
Status
dhuss
