Quick Air Bolt in Tank
michaelgroves
Yeah but dig into their website and the 70 version weighs 180 pounds and the 140 weighs 220 pounds! I didn't see anything on cost but I'm betting it is in the 2500 to 3500 range.
The compressor in the Warn PowerPlant does a good job and the two Warn stand alone compressors seem to be quite capable. The small one is as fast as the PP and the twin cylinder is twice as fast. With my PP when airing up my 35's from 14 to 29 the bottle boys only beat me by a minute or two total time.
Yes, they seem very very specialised. Given that they are 30 times as fast as your top-spec Warn compressor!
WickedZJ
What about using a York 210? I have heard these work quite well for an engine driven compressor. I would love to run one if I could.
chuck45
I think the PP and single cyl Warn are about 4 and the twin cyl is 8 or 9 cfm at 90 psi. If you look at the app charts you can see the small ones are all for pickups, mostly diesel, and the large one is for medium duty trucks. From my perspective, given that my Warn PP airs one of my 35's from 14 to 29 in about 75 seconds, unless the savings of three or four minutes once a day is worth thousands of dollars and 180 pounds (that could be better used) these units make no sense. Unless of course, as their video shows, you carry a jackhammer!
chuck45
Belt-driven compressor is the way to go! :) This is the compressor I want to install: www.extremeoutback.com. Over 200 litres of free air per minute, even at 7 bar.
This looks like a great unit. I talked to them about getting one for my JK a few months back and at that time all they had kits for was diesel pickups. It looks to be a better setup tan the York that Kilby and ORO use though. I wish Extreme Outback would expand thier range of kits.
I have been talking to Warn about a modification of their twin cylinder setup to make it more compact which would make it a much more viable option.
rickc
Chuck45: I was kidding about the VMACs! The VMAC compressors are serious industrial machines for the workplace. They run wet so need an oil delivery/removal system that cranks up the weight considerably.
What I found interesting on the Extreme Outback site was that the ExtremeFlow compressor (very cool) is $414.95 but the mounting kit is $799.95; almost twice as much! Understandably, they only make the mounting kits for a popular range of modern motors with provison for a secondary alternator. For anything else it would be a custom job done by you!
The Hummer set-up is not too bad. My electric compressor puts out 1.58CFM at 30PSI (2.2CFM at 0PSI) drawing air in through a tap into the main engine filter. Here are the specs: http://dodgeram.org/ki4cy/air/pumpspecs.htm
Mine's connected to a CTIS but there is a utility connector for pumping up other things too.
rickc
Try telling that to the paper industry. I have had to work in any unit that comes my way but over here despite Canada being formally metric, the influence of the USA tends to bias things to Imperial/US units. I love the Internet-based unit converters - I'd be lost without them.
For Michael and my other metric friends:
My electric compressor puts out 44.74 litres/min at 2.068Bar (62.29 litres/min at 0Bar)
Houie
