mcvickoffroad said:
What do you guys think of the hand held 2M radios?
I'm thinking you could use it as a portable Hand Held and then when you get in your vehicle you could connect it to the 12v power and a mounted antennae.--???
I have owned a 2m/440 HT for several years now. They are incredibly useful and make an excellent first radio. A 5 watt radio with a quality external antenna is an amazing communications tool. They do have some limitations for vehicle use, however, which include the following:
Tiny controls - Most HTs have very small buttons and displays that are difficult, if not dangerous, to use while driving. If you intend to use mainly simplex frequencies and don't expect to fiddle with the radio's settings much, this isn't a big problem. If you are hopping around the band or looking for repeaters (and thus also doing squelch tone scans) you'll start to wish for a mobile rig with a big, bright display and larger buttons.
Heat management - HTs are great for intermittent communications but they can suffer from excessive heat if used constantly at full power. Using an external power source can exacerbate this, as the radio will be pushed by the full 13.8 volt supply from your vehicle. This can over-drive the finals and result in a very hot radio, if not permanent damage. Turning down the RF output power can help, but then you'll be using less than 5 watts and that may become an issue if your contact is already a marginal one. Mobile rigs have big heatsinks and fans to keep them cool at much higher power levels. You'll still want to be mindful not to drive your mobile radio at full power all the time or for extended periods, but full power is really not required all that often, anyway.
Messy cables - Hooking up an HT with external antenna, remote microphone and vehicle power cables gets old. The cables go all over and sometimes pop loose. HTs are fine for ocassional comms, but using them as a substitute for a real mobile rig all the time does get a bit wearisome.
Limited power - 5 watts is fine if you're near your contact or working repeaters, but low power operations do have their limitations. It's nice to be able to bump up to 10, 15 or even 50 watts when you need it. For this reason I wouldn't depend on an HT for emergency work, but then again I would rather have an HT than no radio at all. You could use an external RF power amp, but you'll approach the cost of an inexpensive mobile rig. I would spend a few more bucks on a mobile and be glad to have the convenience of the HT and mobile at my disposal.
Hope this helps.
