Rancho® 2" Front and Rear Coil Spring Kit for Jeep® Wrangler JK/JKU
Rancho
Supporting Sponsor - Rancho Suspensions
TL/DR
Our 2" coils are now available as a stand alone item!
Note there are different part numbers out back depending on 2 or 4 door.
Check with your favorite retailers on cost.
Specifically tuned to provide superior on-road comfort and off-road performance, Rancho® front progressive rate coil springs ensure that your Jeep® Wrangler JK/JKU maintains a level stance and ride – even while under heavy load or towing. These Rancho front coil springs provide 2-in. of lift height to allow the use of larger wheel/tire combinations without body modifications or fender trimming.
COMPATIBILITY -- Designed for Jeep Wrangler JK/JKU
IMPROVES PERFORMANCE -- Progressive rate springs are specifically tuned to deliver superior on-road comfort and off-road performance
FITS LARGER TIRES -- Provides 2-in. of lift to accommodate larger wheel/tires without body or fender modifications (aftermarket bumpers, sliders, winches affect lift height)
EASY TO INSTALL -- Kit includes two front coil springs that install easily
LEVELS VEHICLE -- Maintains level stance and ride while under heavy load or towing
RESISTS CORROSION -- Powder-coated to resist rust and corrosion
ENGINEERED TO LAST -- Made of high-strength steel that is shot peened and heat treated for long life
WonaWarrior
