Raptor Specs:
Wheelbase (in): 133.1
Length (in): 222.1
Width (in): 86.6
Height (in): 78.4
Curb Weight (lb): 5,888
Ground clearance f/r (in): 11.2
Approach (deg): 29.8
Departure (deg): 26.1
Breakover (deg): 20.8
Max Towing capacity (lb): 6,000
Fuel capacity (gal): 26.0
HP: 320
Torque: 390
'09 Power Wagon Specs:
Wheelbase: 140.5"
Length: 227.7"
Width: 79.8"
Height: 80.6"
Curb Weight: 6,081 lbs
Front Axle Ground Clearance: 8.4"
Rear Axle Ground Clearance: 8.3"
Approach Angle: 35°
Breakover Angle: 25.5°
Departure Angle: 26.5°
Towing capacity: 10,500 pound
Payload capacity: 2200 pounds
Fuel capacity (gal): 34.0
HP: 383
Torque: 404
'10 Power Wagon changes from above:
Wheelbase 148.9
Overall Length 237.4
Overall Height 80.7
____________________________
As a slightly biased owner of a an '09 Power Wagon, I'm not interested in the Raptor for a couple reasons.
First and foremost it's too wide. That extra 6.5" of width will be a real problem. It won't fit on trails I've been thru. No way, no how. I've already pinstripped the heck outta my truck, squeeeeeeeeeked it thru trees and bushes the Raptor won't physically get thru. Ol' Cactus Red looks pretty nice until you get close to it and see all the heavy scratches in it.
Secondly, the 05 to 09 PW is a better trail truck, work truck, tow truck, and dare I say it, much more durable truck than the Raptor. The PW uses 1 ton axles under a 3/4T rated truck. The frame is massive, and will hold up better over years of abuse and use. The stock motor has more power and torque - probably won't get better mileage than a Raptor tho. Throw in the rest of the PW package, and while it may not go as fast as a Raptor, it will go anywhere a Raptor can. Can't say the same thing in reverse tho.
Will the Raptor ride better? Yes. Will a Raptor go faster over terrain? Yes. Will a Raptor haul a camper, even a light weight 4 wheel camper? No. At less than a 1000 Lbs capacity, a Raptor can't haul 4 passenges and a 700 Lb camper without going over it's limit.
IMO the Raptor is a very specialized desert race truck. It does that very, very well.
A Power Wagon is kinda like a Leatherman tool. It will do damn near anything you ask it to, and do it pretty well too boot.
Later!
Mark
