Recommendations on best 'expedition' tire?
Scott Brady
Founder
Ron,
What attributes to the great performance?
Durometer, tread design, carcass segments/deflection, siping, ???.
Were all vehicles modified similarly, weight distribution, articulation, driver experience?
What type of terrain?
Thanks for the help :)
Grim Reaper
I am pretty partial to BFG's.
I have run the BFG Muds HARD in places like Tellico and even on a 6,000lb vehicle I had remarkable tread life. The one set I managed to get 30K out of before I sold them to another guy who put an additional 20+K on them.
I have managed to rip out two side walls. Once was a very sharp part of a tree stump and the other was a very sharp rock in a deep water crossing.
I have driven the vehicle in some heavy rains and as long as you drive at speeds that are appropriate to conditions I have never felt I was in any real danger with hydroplaning despite the large tread area.
I have also run the BFG A/T's. This was on my Wifes K5. That truck was more for the street but we had done some off road in it. Mostly sand in FL. Did quite well in soft sand as long as you keep up momentum. What rocks I was on with it they seem fine. Only thing I had any real problems in was Mud. Never stuck but I could tell they didn't pull as well as the MTs on the other K5.
That said I have several friends that run the A/T on the same trails and had good luck.
I think a lot of the side wall complaints come from people who have abused tires like Bias ply swamper's. Yeah a 10 ply tire is going to handle a lot more side wall abuse. In my cast both my flats I don't feel it was a issue with the tire just managed to find the right place to get the tire.
At the end of the day I'm running down the Hwy at 70mph with no vibrations and they are planning their next dental appointment to get the chips fixed in their teeth.
What I have had bad luck with was Uniroyal Tiger paw A/T's. One of our K5's had a fairly new set on it when we bought it. We took two trail rides on them and after the second ride on the way home we had problems. I kept hearing thinks hitting the bottom of the truck. After two stops I finally figured out chunks of the tire lugs were separating from the carcass and that was the source of the noises. Bought the first set of BFG muds the next day.
My Toyota I recently bought has a set on it. The tires are maybe 5 years old and already have very bad checking around the tread and I feel it won't be long before they will be shedding parts of the tread.
My last work van came with the Uniroyal's and they wore out early and never handled as well as the Michelin's I replaced them with. So 3 bad experiences with that brand.
I am about to be in the market for some tires and on this build up (to get rid of the Uniroyal's) I am heavily leaning toward the BFG AT KO in a 33x 10.5x15. I know what I am getting with them.
Colorado Ron
expeditionswest said:
Ron,
No sipping. I didnt air them down(though it would have done alot better). Tread design is similar to BFG MTs. Vehicles were all jeeps. The one with Goodyears was a Jeep Rubicon so he was locked front and rear. I honestly still went more places than he did with open axles. Terrain was rockie mtns. So a little mud, mostly rock and snow. 2 full days of wheeling. Everyone in the group wheels fairly good and has decent expierience. Plus we all followed the same lines. Snow drifts that I got thru with little issue required a tug on the Rubicon. Stuff like that. Jeeps were 98TJ, 00TJ, and a 03 Rubi.
dieselcruiserhead
16 Years on ExPo. Whoa!!
Back to the top for this old thread. In the end I decided on the tried and true BFG A/Ts.. I cannot remember if they are K/T or K/O (not aware of what the difference is).. But I believe K/Os. The size I needed is 315/75/R17. As far as 17" concerns, as much as I would like to take my truck down south of the border it is not something I ever plan to do with this particular vehicle at this point. It will simply be too nice and flashy IMO beyond Baja only. So this tire will be OK for my needs stateside despite its expensive price.
I did not mention that in '04 I believe after years of obsessing after Michelin XZLs myself, I finally acquired a set. I have also owned several sets of other common 9.00R16 military tires, mostly from military trailers. A post about my impressions of the XZL is here: http://www.expeditionportal.com/forum/showpost.php?p=22774&postcount=17 . I liked the XZLs quite a bit and have a friend with a beautiful build Rover D90 who runs them and they are great on it (other than taking out chromoly axle shafts with hard wheeling due to their weight). But on my FJ55 they just looked goofy, too tall and narrow, and were great on the straights but cornered and handled off camber situations awfully. If you have a light lift suspension with large wheel wells it is an excellent option. But a taller lift (like 4 or 5") and wheel wells that normally fit 35's max, then they look goofy... So I ran them and sold them shortly after...
Anyway, my ideal tire is probably a 34" or so, 11.5 wide but there are very few tires made that satisfy this. I would prefer a narrower contact patch than the common ~12.5" width but have found the ~12.5" width of the bigger 33's and 35's to be OK so I have just run with it.
So, I acquired two 315 75 R 17s fairly cheaply already... Turns out they are a common H2 tire. I let some cheaper ones slip through from when H2s were still popular and a lot of guys were selling brand new BFGs for aftermarket wheels and rims. I lucked out and am probably less than $200 for the two so far - they were that easy to find. But now will probably buy at least two new ones to possibly have some warranty (even at ~$240 a pop) or I might keep trying to acquire some other new ones. My friends with built FZJ80s and BJ42s are running them and they are holding up just great even with a beating and well over 10K miles. Borderline look brand new. So I am excited to run them for now. Good old simple old BFG A/Ts -- who would have thought..
Cheers,
Andre
overlander
pskhaat said:
A little late to the thread here, let me chime in with a product that has served me extraordinarily well over the years. It is the BigO XT. It's kind of a cross between an AT and MT. Anyway, I can't say I'm a fan of the BigO comporate entity especially its sales folks, in fact quite the opposite, but I have had amazing luck with this product.
It is studdable, without siping performs amazing in snow & ice, and has taken a serious beating by countless offroad trips. The last pair of XTs I had for 6 years and about 60k miles, and still a lot of lug left and are on my 40 series now. I have heard folks really badmouth these tires because of the sidewall, but I'm the only one I know that has ever run them; I never had a puncture and those tires ate many hundreds of miles of rock on their sides, not once in 60k miles had a flat or even a small leak? Lucky? Maybe.
I bought them because by default the XT is a free fix & replacement for the life of the tire, yet never had to employ it.
Anyway, I am now on my second set with only 3k miles in. If you can find a decent store, I by all means recommend you at least take a look at them.
Another tire that I don't think you can beat for your $ is the Dunlop Mud Rover:
I was a BFG MT guy for years with my CJ7. Living in the southwest and hours away from civilization in BLM land whenever I could get there, the BFG's never gave me any kind of problem. Countless times pulling teddy bear cholla cactus nodes off the sidewalls. Been to Moab on jeep safari's a few time, and traveling late at nights on snow covered roads into colorado. Still have the Jeep (not much longer though) and it's on it's 3rd or 4th set. Never had a flat the entire time, despite the abuse.
When I got my first Land Rover (disco I) I got cheap and put the Big O's mud tires on it while living in Tempe, AZ. Started off roading and exploring quite often in it in and around AZ. wasn't too long after that I was coming back from the desert with some people from work I was hosting, and one of the big O's burst open while going 10mph. my first burst ever, couldn't believe it. got out and the sidewall had ripped open so big I could put my fist on it. I instantly went back to the moment I decided to go Big O instead of BFG and kicked myself. I'm a BFG guy for life now.
Now i just replaced my oem michelin X's on my 110 for BFG MT's, and the ying and yang have reached harmony again.
My MT's on the 110 are on the original LR tubed steel rims, and they are holding well. I like that i can carry 255/85/16 tubes if I go on extended expeditions down the road, and can slap one in if need be as a field repair. being tubed rims make them much easier to install and remove. I actuall did the tire swap myself at night. 45 minutes per tire. took 30 minutes to get the michelins off (that's some hard rubber to get off those rims), and 10 minutes to install the bfg's and inflate them (with my portable compressor, all using tyre pliers. gave me comfort in knowing I could remove, repair and replace the tires, as well as install tubes if needed, in field conditions if I ever needed the skill.
tires are balanced with Equal. still running smooth as of today.
kcowyo
ExPo Original
Shovel said:
Whenever it's time for new tires, I shop around, look at what's out there, spend hours tossing it back and forth in my head....
and end up getting BFG A/T's.
Me too....:eek:
But I swear, really, truly, the next set is gonna be the TrXus MT's. I'm serious, promise, I'm gonna do it. Stop laughing....
DaveInDenver
Middle Income Semi-Redneck
kcowyo said:
Me too....:eek:
You'll come back to the AT fold. Oh, you will. First snow packed road on MT treads always reminds me why I love the BFG AT so much for all around.
dieselcruiserhead
Back east in Vermont and New Hampshire, etc, I actually loved running swampers. I ran 34 x 9.5 R 15s. Had a super low lift (tires were narrow enough that I got by with very small lift, 2" or less. And they did killer, right to the bottom of any mud or terrain like this... It is a great tire. But loud and one time at about 65, one of the lugs flew off into a wheel well, exposing thick metal layering. I thought it was the loudest backfire or some other explosion. Still held air and wheeled excellently, wire exposed, for years. I guess I saw direct reason why you are supposed to keep them under 60mph. Testiment to complete over built nature of Super Swampers. But I probably won't not run again personally...
kcowyo
ExPo Original
It's the reviews of the TrXus' performance in the snow that have me so amped to try them. I'm gonna do it....
TJVach
Just out of curiosity, which swampers did you run ie. Radial TSL, SSR, Bogger etc.??? I was thinking about running them (SSR's) on my Jeep TJ, but still haven't made up my mind. It's a light truck so tires are totally different then you folks with heavier vehicles.
DaveInDenver
Interesting, very interesting. Doesn't matter in the end, no tall-n-skinny sizes on 15" rims. Why do so few places make 33x9.50/10.50? Why, oh, why!
Colorado Ron
FWIW those Trxus are what Im running on the Pinzgauer. They worked wonderful in that bad blizzard we had here in CO last winter. I was really impressed with their snow plowing capabilities. Also, I believe they are either 8 or 10 ply. So thats a huge plus too. Tough as nails.
Pskhaat
2005 Expedition Trophy Champion
I'm sad so few tires are now studdable. I realize tire compounds have come a long way but I'm still a very firm believer in studded snow tires. I still will only buy MTs that I can stud.
I've also driven on some of the green diamond tires out on Georgetown Lake and was amazed, did much better than the Blizzaks I had.
njtaco
kcowyo said:
Me too....:eek:
FWIW,
My brother runs 34-12.50R15 in this tire under a '74 International Scout. He absolutely loves them in the snow, especially on the icy roads in town. (Scranton, Pa.) The traction on icy snow has saved him in many near-collisions on the downhill intersections, when cross traffic could not/did not stop. The truck has performed better than planned in this environment, and he attributes this in large part to his choice of tire. His other Scout ran Revos, and he was happy with them too, but suprisingly not as with the Intercos.
Oh, he has yet to need the winch with these tires, but he is pretty conservative off-road, as he generally explores alone (one vehicle.):oops:
flipstick
