Removing rear seats to increase payload capacity?
stevo_pct
A lot of F150s have higher tow ratings and payload ratings than a Power Wagon. Oddly enough we considered a Power Wagon to replace the Tundra to carry outt 1200lbs FWC but decided if we're spending some money we should get a truck with a higher payload than a Tundra.
Oddly enough, a Power Wagon has less payload than my F150. But most people wouldn't think twice about carrying a pop up camper on a PW.
bkg
A weight distribution hitch is not required to tow 2000#. Not even close. My point here was just with respect to brakes and transmission. I don't think braking or stopping distance is a factor with respect to hauling 2000# in a half ton truck because the brakes are designed to handle towing that is much higher than that. At some point when towing (I think it's 5000# in Colorado) trailer brakes are required, but from the perspective of brakes and transmission performance, if a truck can tow 3000# just fine, then it can certainly haul 2000# just fine - again from the perspective of brakes and transmission.
My point here is that, with respect to this topic (using a half ton truck to haul a camper), it doesn't seem like braking power, stopping distance, or transmission is an issue.
hauling 2000# and towing 2000# are not the same thing.
stevo_pct
Are you mounting the camper full time? That is a big factor IMO. If is mounted full time and that makes a difference imo. Your rear axle rating would be my concern. Try to stick in those constraints. With the camper you'll get similar mpgs to a F350 with a camper.
I don't think you should buy a truck until you have the camper and spend some time with the set up.
It sounds like both the OP and myself are considering living in the camper full time. In my case, it's really more of an extended (multi month) trip, that may or may not turn into longer term living. During that time (during the trip), I wouldn't be removing the camper. But that might not happen until summer of 2022 or 2023. Before then, if/when I do get a camper, I would take it on when not using it for camping.
stevo_pct
I know they are not, but from the perspective of transmission performance and braking, they are. Or at least they are close enough to say that, if the brakes and transmission are capable of handling much more than 2000# when towing, then they will be capable when hauling 2000#. Explain how it's different. You're using the brakes to stop a rolling 7000# vehicle in both cases.
I'm only bringing this up because some comments above were about braking performance and transmission wear. But I don't think that's an issue for this topic. From what I can figure based on everything said above, it's the axle ratings that are the biggest issue when hauling a camper that brings the GVW to something near or over GVWR. Braking and stopping power should be a non-issue.
bkg
That's like saying that the those same components, if the truck is rated to tow 10,000# (w/ a WD hitch) can carry 10,000#.
I don't agree with that at all.
rruff
No, he is saying that if it's rated to tow X lbs without trailer brakes or special hitch, then the braking, engine, and transmission performance/stress will be no worse with X lbs in the bed. In other words the brakes, engine, and transmission are not the issues... if anything is.
Also note that GVWR and axle ratings are based on the lowest denominator of springs, shocks, tires, axle, etc... on half tons I'd bet the springs are the limiter, since they are designed for a smooth unladen ride. The tires that came stock on my Tundra are nearly at the limit.
bkg
I understand what he's saying. That's why i used the extreme example.
It ignores the additional axle/load carrying components of the trailer as well as the dynamics of the load itself.
stevo_pct
Yes, this is what I'm saying, thanks for clarifying. The brakes/transmission are not the issue.
Todd780
OverCamper
Check out #3
3. Exceeding Your Truck’s GVWR and Payload
A truck camper pitfall many truck camper owners are guilty of. The common refrain we hear is that most truck camper owners are overweight, meaning they’re over their truck’s payload rating and GVWR. Doing this is neither safe nor smart. Why not just buy the right truck to begin with? Yes, we know all of the tricks to “raise” the GVWR/Payload of a truck, like buying larger wheels and tires with higher load ratings and installing helper springs to support the rear suspension, but none of these things will technically increase your truck’s GVWR/payload. Only the manufacturer and a few select shops can do that. That’s what the GVWR/payload sticker located on the door jamb is for. If you’re way overweight and you get in an accident, you’ll get screwed by the insurance companies. If you need to, and you have the means, buy a larger truck with a higher GVWR/payload. Even if that means having to buy a 4500 or 5500 pickup truck.
ChasingOurTrunks
Definitely understood. In my case, I don't want to deal with a setup that is unsafe or doesn't ride well.
... From the perspective of braking and transmission, towing 2000# is the same as hauling 2000#, and a half ton truck can tow 2000 without much extra wear and tear on the brakes and transmission. Or at least it should be well within the design parameters.
I'm 100% in agreement with your philosophy of wanting a setup that's safe and rides well, as that is my goal as well, and so I've tried to learn as much as I can about how weight impacts vehicles over the years. Transmissions are usually not the issue, but brakes for sure are.
Transmission issues are less likely in a truck with a tow package but that has nothing to do with the weight and everything to do with the transmission coolers. In my experience, keep autos cool, and no matter how much work they need to do (towing or hauling, within reason), they'll typically run a really long time with minimal complications or reliability issues. A transmission that is strong enough to tow thousands of pounds will have no problem hauling the same weights, provided it's kept cool.
But, 2,000 lbs in a bed is a lot more impactful on braking than 2,000 lbs in a trailer. The issue is weight distribution. At or under the spec'd payload, the vehicle is typically balanced nicely between front and rear. But if you exceed that payload by putting too much extra weight in the bed, the weight in the back can cause the front of the truck to lift up, pivoting around the rear axle.
The impact of this means less friction up front. In a braking situation, the majority of the work (upwards of 70% I believe) is done by the front brakes, but they are only as good as the friction between the tires and the ground, which is compromised when there's a lot of weight in the back. While the weight will shift as soon as you hit the breaks, even a few milliseconds of having less weight on the front end while this shift is occurring is enough to dramatically impair breaking performance. This is very distinct from towing a 2,000 lbs weight, because that weight is contained behind the vehicle on it's own axle, and the ball weight (the weight that is "lifting" the front of the truck) is usually pretty small (i.e. 500 lbs or less for Class III hitches). Therefore, the weight of the front of the truck is still pretty good when towing 2k lbs, and therefore the brakes work as designed in towing, as compared to when hauling a similar heavy weight in the bed. This is why trucks with a payload of only 1900 lbs can tow over 9,700 lbs (specs pulled from my 1500-series pickup that I just sold).
The issue for the brakes isn't wear and tear; Stopping more weight absolutely will wear out pads faster as there's more moving mass to slow down, and the brakes do that via friction, so heavier trucks will go through pads faster, and that is true whether they are towing or hauling. The issue is what happens in an emergency, and that is why this impact to braking is so important to parse out a bit.
Put simply, weight and stopping distance are proportional -- if weight is doubled, stopping power must also be doubled. You can offset this "shift in weight problem" I described above with a well designed suspension system -- one that holds weight better in the rear end and prevents the front end from pivoting up. This works in theory, but that doesn't typically translate to a good idea in emergencies. There's two issues -- first, in order for a suspension system to do this load carrying well, it needs to be engineered holistically with the rest of the vehicle (brakes, tire sizes/ratings, suspension geometry under load, drive shaft angles, CV joints, wishbones, etc.). In order to properly uprate a vehicles payload, you need to switch a lot more than just the suspension. A good example of this is the Australian rigs -- often to increase payload, they are scabbing in frame braces, axle gussets, and so much more than what you get in a typical 'suspension kit'. These are signed off by proper engineers, as is required to be legit in Australia. In fact, I don't know of a single reputable suspension kit that even claims to increase carry capacity -- all they do is improve performance near max GVM, because that's fairly easy (tune the shocks and springs to match the weight) relative to increasing GVM.
The second problem is that upgrading the vehicle can give you false confidence and make things way worse in emergencies. If you do put in airbags or stiffer springs, odds are good that you can make the truck "feel" pretty good day to day. It'll handle well, probably won't feel too underpowered, etc. But that math from earlier -- if weight is doubled, stopping power must also be doubled -- has a cousin "law" about speed: If speed is doubled, stopping power must be quadrupled. More confidence usually means more speed.
So lets make up a story that illustrates how this all comes together to make big problems in real life. Timmy and his truck are driving down the road. The truck is stock with a 1500 lbs payload. Timmy has it loaded for bear though, with a 2,000 lbs camper, his 250lbs self, 500 lbs of miscellaneous recovery gear and camping kit, plus food, water, and the dog so he's sitting at 3,000 lbs of weight. Seems extreme, but doubling payload isn't that uncommon when campers are involved. He drives his stock truck down the road, but once he gets north of about 60 kph the steering starts feeling really light, and the front end starts drifting back and forth. The tiniest input into the steering wheel causes the front to "float" around and it's deeply unsettling as a driver, so Timmy slows down a bit and nurses his truck back home at 50 kph, where things seem to settle down a bit. He's obviously too heavy, and the car isn't safe to drive. If you want to see what Timmy was feeling like, go put a yard or two of gravel in your truck and go for a cruise. Keep adding gravel till you notice a difference in handling -- it won't even be over the bed rails before you start feeling what Timmy felt in this story, and it usually seems fine until you hit a certain speed.
So anyway, Timmy knows he's too heavy so he hops on Expedition Portal, asks for advice, and decides to shop at one of our vendor partners for some airbags and upgraded springs. The next weekend he's out and whoo-boy, his truck is handling like a dream. The front end stays stable past 60 kph, and pretty soon he's able to cruise down the highway at 100 kph. Truck feels great, everything is working well. Little does Timmy know, Bullwinkle is visiting the salt lick in the middle of the road about 100 feet ahead.
Timmy's truck as it came from the dealer (and let's say it's only loaded to max payload) could stop in about 60 feet at 100 kph. He'd be safe from Bullwinkle because his truck performs as it should.
Timmy's truck loaded up to double his payload, but before his upgraded suspension, would theoretically need 120 feet (double the weight, twice the distance) to stop from 100 kph, which means Timmy would be rushing to a date with Bullwinkle, but since his suspension wasn't upgraded the other day, the truck clearly told him that he wasn't able to go much faster than 50 kph. His stopping distance, overloaded as he is, is probably still under 60 feet at 50 kph, since he's not going that fast. So, if Bullwinkle made a showing the other day, Timmy would probably be fine and stop in time from 50 kph down to zero to avoid a Moose Surprise. And, he'd think "Gee, that was a close one. Glad this truck's brakes worked good". And he'd be wrong about that -- they'd feel good, but they would be performing extremely poorly relatively speaking, but because he was still able to stop in time to avoid the moose, he doesn't really notice that his brakes are now garbage. Remember, he was only going 50 kph here.
But today, with Timmy's upgraded truck's better suspension that lets him cruise at 100 kph (double his speed of the other day), fully loaded with his 3,000 lbs of gear, and with Bullwinkle 100 feet away on the road ahead, Timmy has a problem. He now needs 240 feet to stop his truck (4 times the distance). Essentially, that's almost an extra football field of distance. With a total stopping distance of 240 feet, Timmy is only half of the way through his braking distance when he hits the moose -- that means it's not even close. He hits that moose at near highway speeds. It doesn't go well for Bullwinkle, but it goes a lot worse for Timmy and his dog; the moose goes up over the hood of the truck and into the cab, right beside Timmy. Timmy gets a hoof in the head from the moose thrashing around, and dies slowly on the side of the road.
The dog is fine though and lived happily ever after.
The moral of the story: Timmy should have bought a truck rated for the weight he needed, because a suspension upgrade on it's own is not enough for a truck to carry a camper it wasn't designed for. And dogs are too pure to die in stories.
(The above is super simplified and doesn't account for reaction times or anything like that so the math might be off by a bit, but my goal is to illustrate the order-of-magnitude impact of weight on breaking distance in a "real world" scenario).
Buddha.
Finally in expo white.
The issue for the brakes isn't wear and tear; Stopping more weight absolutely will wear out pads faster as there's more moving mass to slow down, and the brakes do that via friction, so heavier trucks will go through pads faster, and that is true whether they are towing or hauling. The issue is what happens in an emergency, and that is why this impact to braking is so important to parse out a bit. P
But today, with Timmy's upgraded truck's better suspension that lets him cruise at 100 kph (double his speed of the other day), fully loaded with his 3,000 lbs of gear, and with Bullwinkle 100 feet away on the road ahead, Timmy has a problem. He now needs 460 feet to stop his truck (4 times the distance). Essentially, that's an extra football field of distance. With a total stopping distance of 460 feet, Timmy is only 1/4 of the way through his braking distance when he hits the moose -- that means it's not even close. He hits that moose at near highway speeds. It doesn't go well for Bullwinkle, but it goes a lot worse for Timmy and his dog; the moose goes up over the hood of the truck and into the cab, right beside Timmy. Timmy gets a hoof in the head from the moose thrashing around, and dies slowly on the side of the road.
Everyone knows Toyota’s are super overbuilt though so in real life Timmy would be fine.
ilciclista
