Thought I would be smart and use Jaymors 1915 on my battery posts. It's the best light lube I have ever used, but most important, it does not smell and does not give me a rash. That means it can be used inside and near the coach with no worries:
Jaymor's 191S is an all-purpose synthetic lubricant with residential, industrial, care facility, and farming uses. It is a high performing and an environmentally friendly lubricant product for homes & businesses since 1993.
www.jaymors.com
Problem is, it's too good! It coats parts with a lube layer that will not conduct electricity. It penetrates like crazy too, and loosens up friction fits.
SO, I did this a while ago and it sat, everything looked pretty over that few weeks. But when I went to start the engine a week before an important trip, it turned over for something like a half-rev and then the starter quit. The starter was the original, so I replaced it and cleaned up the battery posts and all other connections with spray bake parts cleaner and ScotchBrite. All clean and dry. Everything worked great. I figure the ground connection opened up and the starter solenoid coil burned out.
Then I noticed that the alternator was not producing current. Years ago, the original alternator blew a diode and I replaced it with a single-wire aftermarket. The aftermarket solid state regulator was damaged by the starter solenoid coil sending a high-voltage pulse to the wrong place. The body of the one-wire alternator was smaller than OEM, so I had made an adapter bracket. Worked great for years, but now, it was blown. Went online to look for a new one, but was in a hurry, so searched retail too. No joy. The supply chain or something made this single-wire aftermarket a long-lead-time item.
I had ditched the stock electro-mechanical regulator long ago. Time was ticking. So I went on-line and found the recommended electronic alternator according to O'Reilly's and Autozone for a 1994 F350. Adapted to that (bigger, new connectors). Went on the road, only lost a couple of days. Had it blow out near Barstow (factory rebuilt). Limped back home, running the coach generator with the coach-to-engine shorting solenoid energized. Just made it before sunset, was afraid to run the headlights because the coach shore 110V to 12V power supply could barely output 7 Amps, which is almost the nominal running current for the truck.
Researched Ford alternators and found out there was a later generation that was better all-around. So I searched for the 1995 alternator and got the right thing. Required another new and expensive field connector. Anyhow, it all works now but was a real panic and a pain. It's all fun and games until something breaks.
Moral of the story: DO NOT use Jaymore's on electrical connections!
AND, we made it to our event, but without the few days that we were going to spend relaxing beforehand. This event is something the Wife Unit and I have been volunteering at for years:
www.nps.gov
Was so busy interacting with the public, I did not take photos until afterwards. Points for who can guess where this photo was taken:
- Hellwinger
