seanpistol
I want the bronze 3.5" BS F5s on my white truck... bad. :drool:
I will be following this build very closely. Your plans are fairly close to mine, however I already have the child mod done. A single rear facing seat fits in the AC without hindering the front seats (Chicco Keyfit 30). I think once we are able to turn her around it will be even better. To me the size of the AC is perfect for a 3 person family. If you have 2 kids, things might start getting tight.
Is it possible to swap in a 8" front diff from a 05-07 Tundra?
I'm sure you could... but it's not going to bolt up and I actually think the new Tundra front diff is a 9"??. The widths would be totally different and would require custom front everything. You'd probably be better swapping in the entire front end including CV's and control arms. I think an easier (but still very custom) would be to swap in the 8" (I know this is an 8" version...) IFS diff from the 2nd Gen Tacoma/FJ/4Runner.
I'm so stoked to see this come together finally! I've always loved your 80 and it almost made me want to trade my Tundra for one but I just can't give up on the truck part.
Have you thought about going with fiberglass fenders in the front? I've seen a few for our 1st gens and it seems like an easier way to get 35s under the front.
Here for the pictures![]()
The Tundra is going to be nice; on road, off road, at work, in the Koots.. nice-nice-nice.
Ahh, kids, don't worry about it too much- they'll fit, they're bendy... otherwise you end up driving a Tundy-Crew or some huge minivan..
Our Taco DC does great with two little ones and a 65lb lab- and we're still a few weeks away from both forward facing goodness.
Good choice! It will be good to see another done up tundra in alberta!
I was under the impression that all Tundra's 05+ had the 8" up front. I know the newer 07+ have the 9.5 or 10.5 out back. I would think the width on a 05-06 Tundra 8" front would be the same as your 04, not positive though. I remember doing a lot of research before buying my 05 a few months ago. I knew I wanted to get the stronger front diff and was researching how hard a swap it was and if it was even possible. I stopped because I found an 05.
http://home.4x4wire.com/erik/diffs/
*Well the later Tundra's definitely got a 9", not sure what year it started and if it was across the board.
**It looks like all 07+ (2nd Gen's) have the 9" front. I can't find anyone online that sells anything but 7.5 (front) gears for a 1st gen. Do all 1st gens have a 7.5? I'm so confused.
As others said, can't wait to see your progress. One thing I did not like about removing my rear seats in my tundra is it got really loud. It's amazing how much sound the rear seat absorb. I even had my whole truck sound deadened and it was hard to talk. But there was a lot of room when the seats are removed, you could easily make use of it.
I very much look forward to the developments here! Take it slow so we can take notes![]()
When you do your lift, seriously consider a diff drop kit and replacing your front boots that are close to the diff. When old stiff boots get cocked at an angle that joint next to the diff will get compromised. I used the Off Road Solutions black softer compound boots which solved a serious issue with chucking grease. Others have just used the hose clamp mod but I prefer the approach I employed. See my build thread for details.
Welcome to Club Tundra.
Looking forward to seeing where you go with this... 1st Gens rock!
Doesn't look like the new drivetrain is any good anyways. I rather stick with the 7.5. Don't hear them fail much if at all?
http://expeditionportal.com/forum/showthread.php?t=132915
I'll second that. I'm running Kartek Bates 930 boots.
