PhulesAU
Here, this will solve 80% of the problem.
http://cgi.ebay.com/ParaDynamics-PD...emQQptZLH_DefaultDomain_0?hash=item5885bd744a
So... is this a poor location?
I can't think of another place on the truck that would work.
Mobile Antennas:
The Compromises of Placement vs. Performance
http://www.olypen.com/craigh/antennab.htm
A tuner makes the SWR look good. It not going to make an poor antenna a good antenna.
I just read through this and what he has to say is technically right on.It may not be convenient to do it right but at least you will understand that mounting it on the bumper or bull bar is a compromise to performance.Interestingly enough, on our 1/4 ton trucks (when I served as a radtech) the antenna (with a tuner) were mounted on the rear cab corner of the trucks and on the radio trucks they were mounted on the rear box corners.![]()
Today I put an SWR meter to my brand new CB gear - midland 540, firestik four foot adjustable, and 18' firestick coax. Right out of the box it hit 1.25. No adjustments of any kind were made. Can this be right?
Ok I just got a new antenna and installed it today, I was tired of messing with it. I got a Wilson lil wil and mounted it ********** dab in the middle of my roof. It works very well. I can transmit and receive 5-7 miles. But I have another question.
My SWR meter instructions say to check the SWR in the middle of the cb band and recommends channels 11,12,13. When I do that my SWR is 1:1. But I have always checked it by doing channel 1 and 40 which is also what the antenna instructions recommend. When I do the channel 1 and 40 method I was finally able to get it to balance but the SWR is at 2.8??????
It works fine so far but is 2.8 to high??
(in case someone asks I did it several times in an open area with all the doors closed to make sure I was not getting any interference)
