Rivnut weight capacity
Plusnut
You might want to check out the Plusnut fastener. It is advertised as being better for thin substrates. It does have a large load bearing surface when installed - probably larger than conventional rivnuts.
I do not have personal experience with them in thin sheet metal or fiberglass.
Plusnut®
Cardinal Components carries Bollhoff Plusnut® Blind Fasteners for the the most rigid fastening. A Plusnut® is a blind, threaded fastener recommended for rigid fastening in sheet metal, fiberglass and plastics. The slotted shank spreads and forms large flaps to evenly distribute working loads over a large area. Bollhoff Plusnut® fasteners are ideal when you cannot access one side, or if it is very difficult to do so. The Plusnut® is easy to use and yet maintains the strength and integrity needed for industrial or heavy duty applications.
Bollhoff Plusnut® fasteners provide incredible pull-out strength, as well as grip. Where strength is the main goal, this is an ideal fastener to use. Plusnuts® are also ideal for a variety of applications, as both soft or brittle materials accept this fastener optimally, and without damage to the softer materials.
http://www.cardinalcomponents.com/plusnut.html
Plusnut®
Ive also never used them, but I worry there is no ridges on the portion that goes through the panel like on a rivnut. Id worry the plusnut might spin because of that.
Plusnut®
I just got my metal and rivets today, after actually handling everything, my materials are more than enough to hold the boats, I'm stupid excited to be able to haul my boats, they make trips up into the Northern lower peninsula so much better
I used Plusnut once for an automotive sheet metal application. Size was 1/4-20. Installed them with a hand tool and two wrenches. They did not spin when I torqued the bolts. Might be a different story if they had to be removed.
Removing them and having them spin is more what I had in mind.
If you use one of these to install them you will have no worries.
They work very well, Be aware their surface flange protrudes a fair bit more than a typical 'Rivnut.
Removal is easy as drilling off the flange, their guts fall into the void to rattle about & drive you nuts !!
Good point - the amount the deformed flanges extend can limit where they can be used.
As to another rattle......in my FJ60, I would never know the difference.
I like to install rivnuts with loctite on the exterior to help prevent spinning. I also only use the high strength knurled rivnuts and install them with the manual tool that requires 2 wrenches or the rivet gun like puller for sizes smaller than 5/16". I use only 10-32, 10-24, 1/4-20, 5/16-18 and 3/8-16. Keeping the hole you install them in as close to the diameter of the rivnut itself is best for strength and to keep the nut form shifting off center as it's pulled.
which loctite would you use on a rivnut?
My rivnut setter is a manual, similar to the one shown above, and it is a major PITA to set nuts at strange angles or in tight spaces. I recently bought a pneumatic rivet setter (for blind rivets) because I had to do a bunch of them on a project. It is wonderful! If I ever have to do any more large or large volume rivnuts, I'm getting a pneumatic setter.
nahuebsch
