Capt Jon
I have a charging problem, and I think I now have a way to solve it by shifting around some components, but I would appreciate some feedback from the experts here.
I daily-drive, and play, in a 1990 FJ62. The factory Toyota alternator puts out very low voltages once its warmed up. Often tripping the disconnect on my Blue Sea ACR at stoplights. I supplement with solar and 120v charging to keep the house battery (FLA Group 31 mounted under the hood) charged. But it's an uphill battle.
I recently acquired a new Turtleback Adventure Trailer. I ordered it with an AGM Group 31 and a Redarc 1225 DC-DC charger, but I doubt I will never get 25 amps through the 7-pin plug on the cruiser.
I have very little running on the trailer electrical. The only reason I ordered it with this setup is that I may eventually run a propex heater and/or a second fridge from it. The cruiser carries the fridge now, and I don't anticipate changing that. So I now have a trailer with very little electrical load, but a much better battery and charging system than the one in the truck that actually sees heavier use.
I know that a DC-DC charger should be placed as close to the battery as possible to avoid voltage drop, but that this can be mostly mitigated by larger cable.
My question is this: Can I move the redarc from the trailer to the Land Cruiser in place of the blue sea ACR (thus bumping the charge the house battery in the Cruiser is receiving from 12.8-13.3v to about 14.4), and run a heavy gauge cable from the house battery to the trailer via an Anderson Connector at the bumper (so the trailer battery will see slightly less than the 14.4 the house battery in the Land Cruiser is seeing).
My thought is that this would drastically improve the charging of the house battery in the truck, and only marginally (assuming heavy enough cable) reduce the charge going to the trailer. In fact, the trailer will likely get more through this setup than it would via the 7-pin trailer plug. Though in truth, I will probably run the heavier wire and Anderson connectors whether I move the Redarc or not.
I do pull the trailer with multiple vehicles, so I will need a switch to divert the charge going to the battery from the 7-pin plug or the Anderson connector. It seems to me that allowing them to be connected at the same time would essentially be connecting the house, trailer, and starting batteries together via a small wire and the Redarc. That might release the magic smoke from inside the Redarc, or just set the truck on fire when the insulation melts off the wire on the 7-pin.
Other than the shame of cannibalizing the beautiful work the guys at Turtleback did, what are the drawbacks?
