Roll cages, your views
4Rescue
JohnC said:
Dave,
It's not too bad getting in and out. One problem is that you can't move your seats all the way back. The rear is a bit tight getting in and out but my kids don't mind.
It's a 95 DI.
I removed all carpeting and used Herculiner paint on the inside. I even removed the cloth on the headliner and painted it so I can easily wipe off the mud.
Awsome... Bummer about the seat adjustment, but in general: Just awsome.
gordo
Nice Karmann Ghia in the background of that roll cage shot. Ive had a few of those through the years. Just sold my 66 to finance my series hybrid project. Gordo.
gordo
Michele said:
My thought exactly.
The cage I bought came with more tube mounts (other that the flimsy things at the front) which bolt to the mid and rear hoops,go trough the wheelarches (big holes) and then the ends are "weld on" (to chassis rails).
I attached two files.
A mate pointed out all this will reduce the chassis ability to flex in some way,and I'd hate to turn my Rover into somewhat stiff like a M1 tank...
I'd like to modify the cage in some way but can't see how...
I would not worry about it Michele, you got the cage because you obviously need it and I dont think it will hurt anything if it is a bit stiffer. By the way, did you get the X cross for the inside of the truck. Those photos (completed ones) are were I got the idea for my truck and ran a cross inside. I think that is about the best thing you can do is to triangulate the exo. Gordo.
Michele
Personaly, I WANT my suspension mounted to as rigid a "frame" (...)all that flex can lead to ill fitting doors and body panels etc. which leads to leaks and other bad things
Dave,
I wasn't having a go at you/Matt's cage above...
BTW,ill fitting doors and leaks come standard with almost any Rover so it's the last of my troubles
:xxrotflma
gordo said:
I would not worry about it Michele, you got the cage because (...)did you get the X cross for the inside of the truck. (...)best thing you can do is to triangulate the exo
Hey Gordo,
I agree in the end I'll have the cage fitted as it's supposed to be (weld-on brackets to the chassis etc),and see how it goes,may modify it later (yeah,trying to kid myself here,I'll have no more will nor money to do that once the cage will be in place,I know!!Ha!)
This cage will be a work in progress anyway,as I change the roof accordingly to my mood/need so I'd like something modular which works either with the full SW roof & the truck cab.
I think of a removable X or at least 1 diagonal bar /...
Bolt on I guess?
Chucaro
JohnC said:
Chucaro,
I have the SD internal rollcage that goes thru the dash on my DI.
Eventually I'll have it tied into the frame.
Salu,
Giampaulo
Hi John, that is a good set up, I just sold the Disco and I am shopping for a Defender or a Range Rover so my plans for a roll cage are going to be on hold for few weeks.
I am currently touring in Tasmania where are awesome 4wd tracks. I posted some images in the expeditions section.
Looking at your address is nice to see NY/Uruguay. I born in Montevideo and come to Australia in 1969.
Cheers and keep in touch
DBS311
Anybody got pics of the internal cages used by the CT Discos? I'm interested to see how they tied the roof rack into those cages.
R_Lefebvre
Very good discussion here guys. I would just like to add that you REALLY should have proper padding on those internal cages. And by proper, I don't mean that pipe insulation one person showed.
Race cars have started to move away from allowing pipe insulation as rollbar padding. There are now new materials engineered specifically for this application. You can get SFI rated padding in the USA, and FIA padding in the rest of the world.
You can see it here on the cage of my trackday car:
It is a more of a rigid foam, which at first might seem counter intuitive. But, if you want to understand the reason, take your pipe insulation and whack it with a hammer. You'll feel quite a hard blow on the surface underneath. With the proper rollbar padding, you can hit it very hard without hitting the substrate.
For reference, look at any helmet. Is the insulation soft and squishy, or is it firm?
It's great that you add rollover protection to your vehicles. But if the vehicle survives but you or a passenger does not because of a head injury, then what is the point of a cage?
This padding should be added to any surface you can possibly hit with any part of your body. You'd see I added it practically to the ground along the A pillar. It's also on both the windshield hoop, and the B pillar main hoop.
IXNAYXJ
The padding issue is a great point. As someone who has gotten a concussion from my track car (driving on the street, no helmet), I can completely vouch for the importance of GOOD cage padding. That's one of the reasons I like the hybrig cage I built; there aren't any bars to hit my head on.
My 365 RWHP Miata MX-5.0:
-----Matt-----
Ron B
I put a cage in my hummer last June (been out of town for almost a year working, now I'm back and addressing the padding issue).
I bought the half circle sfi-rated stuff...it's waaaay harder than I thought it would be. I know it's really designed for impact with a helmet, but it will be better than pipe insulation (or god forbid, raw steel) in a crash. I was thinking of adding some additional padding in the areas one's head will most likely contact (the self adgesive 1/8th inch thick rubber stuff). Maybe it's the wrong stuff for my/our application?
this stuff is what I got:
http://www.pegasusautoracing.com/productselection.asp?Product=2395
maybe should have gone a softer route:
http://store.summitracing.com/partd...t=KIR-99003&N=700+4294920026+115&autoview=sku
It just came in the mail yesterday...I was considering returning it and just getting the usual offset full circle type non-sfi rated padding (second link above), but it's a soft top and thought it might interfere with the top's fit...plus finding that stuff for a 2" pipe aint easy!
what do you guys think?
rb
R_Lefebvre
I absolutely think the harder stuff is the way to go, even without a helmet. That Kirkey stuff is junk. Might as well not have any padding at all for all the good that it does. If you're really wondering if the good stuff is too hard, just compare it to the A pillar trim on any car from the factory. They don't make the trim hard for no reason, it's specifically designed for head hits.
I'll always regret not bringing in a sample of the FIA padding to a supplier I worked with who had a HIC rig. Would have been interesting to know how it compares to OEM. I'm surprised nobody has tested it yet. (or maybe they have, I haven't looked in a few years).
Ron B
thanks for the fast feedback -- I agree with you about being safer. I've been on-line reading about testing and there are many comparisons to the plastic in auto interiors. I think I'll go ahead and put it in and maybe soften up the sections I'm more likely to hit with the thin foam padding I mentioned above. I'll post a picture when I'm done.
rb
R_Lefebvre
Are you worried about bumping your head getting in and out, or while driving? My Focus has a high roof line, and I'm strapped in with a 5 point harness, even on the street, specifically *because* of the cage, so there's no chance of bumping it while driving. I don't think you need to worry about getting hurt getting in and out. If the cage is close to your head and the road is bumpy, maybe you could worry about that. I still don't think it would *hurt* much, but you'd feel it. You could try the soft stuff.
In race cars, there's a concern about flammable materials inside, and IIRC, the FIA padding is flame retardant. Probably not worth worrying about with the soft stuff you're putting in.
Another option, if you have money to spend or a REALLY helpful wife, have somebody sew up a padded fabric, velcro closed sleeve to put over top, just like the Jeeps used to have. That would really make it look nice, and give the dual level of protection you want.
One note, the BSCI brand padding I bought didn't work out too well with the self-adhesive strip they put on. I had to zip tie the cage. Others have had the same problem. If you use large black zip ties and trim them, do a neat job, it doesn't look bad at all.
ntsqd
Heretic Car Camper
Did the adhesive fail on the tube, or on the pad?
I ask because it seems like this would be a natural place to use one of the 3M VHB tapes, but if it won't stick and stay stuck to the padding then it could be an expensive experiment.
R_Lefebvre
It was about 4-5 years ago I did this, but IIRC, the tape didn't stick to the tube. It was ok on the straights, but on the curves, not a chance. I also questioned it's ability to hold the padding in position when it actually takes an impact. It just seemed best to zip tie it.
I'm not sure if it is the 3M VHB tape I've used, but I've used a really high quality grey 3M padded dual sided tape before with mixed results. It works well for light duty applications, such as sticking down satelite radio or GPS antenna, but I've also used it to help hold my WRC spoiler on the hatch, and it didn't work there. The spoiler attached with both studs, and tape. The tape has released, but the studs remain. That's a difficult application though, as the spoiler actually generates some downforce, and overhangs the hatch.
I know I used the tape somewhere else it failed also, but can't remember what.
Goldenbora
