TeriAnn
Alaska Mike said:I haven't decided yet, but a GM Iron Duke (2.5L I-4) backed by a T-18 and a Spicer 18 sounds interesting. There are others that I'm looking at, but that looks to be the cleanest install with the least amount of hassle/overall expense. I need to do some measuring to see if the package is feasable, and a lot of this depends on the condition of the stock drivetrain/engine. The axles will probably stay stock
I have a Ford 302, t-18 & Series transfercase in my Land Rover. The T-18 will fit but you will have to modify the bulkhead a little for additional bellhousing clearance, fabricate a new tunnel, modify the seat box where it supports the rear of the tunnel and cut a little off the side of the passenger floorboard.
If you are going to install an Iron Duke, may I suggest a GM gearbox such as the SM465. You should be able to find off the shelf components for a GM 4 cyl engine and there are adapters available for the Dana-18 transfercase. http://www.novak-adapt.com/catalog/kit_462.htm
Before you start ripping things out here's the basics about what's there:
The engine is factory rated at 70 HP @ 4000 RPM & 120lbft @ 2000 RPM. It is easily modifiable to about 90 hp with a Rochester carb, shaving the head to 9:1 compression, a 2.5L LR cam and going up one diameter on the exhaust tubing. A full out performance engine using a lot of expensive parts from the UK will get you about 115 HP. The engine weighs about 450 lbs and you can expect something in the neighborhood of 15 MPG highway.
The gearbox is an updated version of an early 1930's design. They are reliable up to around 160lbft of torque. Beyond there you might consider wing nuts on the mounting bolts. The Series III version is an all syncro box. The box tends to die early if someone tends to shift quickly. You want to hesitate a little at the middle of the 'H' to help the syncros work with minimal strain. These gearboxes work OK with GM iron Duke engines and 200tdi engines from early 1990's Defenders (about 30 MPG highway).
The transfercase is about as strong as any transfercase on the market. It is stronger than a Dana-18. About the only way you can kill one is to run it out of oil. Then a new set of bearings & gasket kit gets it running again. But no one make adapters for them that allows them to be bolted to US gearboxes.
The 88 rear propshaft is quite short. You don't want to do anything to make it shorter.
Series Rovers use 10 spline axles except for the Salisbury (Dana 60 built under license). The 10 spline rears break easily. Thankfully Land Rover has full floating axles. Your easiest solution would be to contact Bill at Great Basin Rovers and order an ARB locker set up for 24 splines, and a set of 24 spline rear axles. Front 10 spline axles seldom break with a LR 2.25L engine. 24 spline upgrades are VERY expensive.
Your easiest engine power upgrades are the 200tdi from a Defender or a Rob Davis engineered GM 4 cyl. Both use the series gearbox.
Anyway, that should be enough to start you started on the upgrade process.
