Has anyone installed Russell Speed Bleeders on their FUSO FG, and if so which version (P/N) did you use? Have to match both thread size and taper angle.
I've used them on my motorcycles in the past, and they make bleeding the brake system easy and a 1-person job.
This comes up now because I'm up in Prudhoe Bay (Deadhorse actually), AK, with a failed front right brake hose, due to a rock strike somewhere south of town. Fortunately the line didn't pop and start leaking until I got into town. Have a brake line on order from Tom's Truck, which should arrive in 2-3days. I'll install it, but then I'll need to bleed the system since the reservoir got drained in the process of figuring out the issue.
Probably too late for the Russell's on this incident, but would install them on the future if I can find a set that fits. Will likely have to pay big bucks at a shop to have them bled this time.
Doug
PS, ran into Reed Resnikoff in his FX up here the past 3 days. He's headed back south now. Weather is in low 30's and 20mph winds.
Doug
