Please make sure you get the diffrential drop kit (1"), I just went through having to replace BOTH axles because I went a week without getting the drop kit after getting my lift.
Both inner axle boots finally tore open after being over-stressed from the lift without the drop kit. It can easily be installed yourself.
The only trouble I had was I could not put two skid plate bolts back in, they wouldn't reach, but all of the outside bolts worked just fine. Make sure you leave the skid plates together and remove as one item, as one set of bolts simply holds those two pieces together.
Bud Built reports that his skids work with all bolts with a diff drop kit.
