SAR JK r2.8 Cummins conversion
superbuickguy
in other news, moved the Jeep around and got a quick snap of it with the lift
superbuickguy
a bite at a time
the adapter to the PS pump
and connected
and then the almost right belt.... I ordered the one size smaller - this will work but it will lose tension the moment it starts stretching
installed
thinking this is where the filter will go....
and classic, it works
but lost one bolt
it should work (stock radiator)
new panhard bar, just waiting for install
superbuickguy
Went to Portland to visit dad so didn't get a lot done... however
installed the new, adjustable panhard
and new stabilizer
then spent quality time seeing what it would take to make this fit
this is now redundant
Cummins makes a shorter oil filter... less fittings, sure less cleaning (but there is a work around with a Franz style filter)... that said this is a every 3k oil change so I'm not as worried
then got to work on the tank.... ordered the fittings and hose, should be here Tuesday
Thankfully, with all my spare time, an old guy had a medical emergency and nearly head-on ran into me. Hoping he has insurance... glad he's not dead, it was touch and go there... it's odd to go from victim to rescuer in less time then it takes to type this....
Oh yeah, all while on my way to church (he was headed the wrong way ;) )
superbuickguy
back to Jeep content
I've had the 'other' window since Woodinville - so giving it 2 years to age seemed like a good idea. That and I'm waiting on parts so time to get other stuff done
and the insert
and the window removed
removal tool
a bit of windshield glue and it's in place
back to diesel content tomorrow
superbuickguy
back to it.
$200 later and the right belt
one that works (neither of which came from Quickdraw) but note how very little space there is between white marks? that white mark is where the tensioner is when no belt is on
this is the correct belt installed - note the white mark on the tensioner?
now that's sorted... time for my nightmare
superbuickguy
Fittings arrived
didn't buy enough hose but napa carries it so it'll be fine
disabled the electric pump - found nice metal bits in the well
removed the one way valve in the assembly to disable the pump. It's still in there in case I ever LS this or need it but now it's most certainly off
this is impossible for Jeep dealership mechanics.... snapping the fittings together - no maybe y'all see why I'm so irritated at them. Even engineers could fix stupid
need to get a 5/8 overflow hose
get the tank in, then realize I can't get it all the way in because the lift is in the way
Dan Grec
I'm really interested to see how the wiring goes and how all the stock functions work.
I really hope you can get 100% functionality from everything electronic!
-Dan
superbuickguy
after a bit of research, it all went back together then the intercooler
I got a 'deal' on this (meaning only about twice what the parts would cost alone) but this is for a JK with a supercharger - so some connections required
but it all, basically, bolts in place
you'd think I'd have tubing to connect this.... but no so I wait
we'll get back to this and in the meantime build coolant tubes and get onto wiring
DanoWall
