SAS info and parts thread
Toasty
Weighed the truck at all 4 corners; front left was 1300lbs and the rest were 1200lbs. Ordered a pair of Kings from Accutune, the first set got straight fittings and i ordered the second with 90's. I'll get 90's for this set later. Painted all the bare steel and installed the shocks to finally sit the truck down on its own weight after four months.
Wrapped mine up with some new double cardan driveshafts, interesting thing was that the Montero 9.5" rear diff pinion flange had the same pattern as the Ford F-250 but metric and female. Tom Woods was able to machine a pilot to fit the Montero pinion flange and Ford 1350 companion flange so all i had to do was use SAE bolts. Made some good progress on PA_JERO's SAS as well by this point, every time i made a part for my truck i also made his parts. I started mine 2 months before i started his and finished them both weeks apart.
20191118_120555.jpg20191118_120525.jpg20191111_100746.jpg20191113_083158.jpg20191126_220422.jpg20191020_121907.jpg20191020_121832.jpg20191125_172207.jpg20191124_130352.jpg20191125_172304.jpg
Toasty
One thing i learned is it's a tight fit, getting the steering and panhard rod all the way i wanted took a lot of work and it's still not exactly how i wanted. I'll probably draw up a new panhard mount for the axle side to make it easier on me if i ever do another one or someone else does.
Toasty
Mid term report, it's AWESOME! Drives better on road and off, balance is still there and its very predictable. DO NOT GET A REMAN STEERIN GEAR! I had been fighting a steering dead spot on both trucks caused by worn sector shafts/bores, i bought them from a reputable Bronco restoration company and it was complete with hydro assist ports and was not cheap by any means. I've discovered this is a common thing with the Saginaw box rebuilds and it's almost universally acceptable (American truck guys must have lower standards), we got brand new steering gears from Benchwork Steering in Scottsdale Az. Problem solved 100% and both trucks drive better than a modern solid axle truck. Luckily we are getting refunds on the reman units.
If anyone in Az wants to go for a ride let me know :D
Michael Brown
You followed me, so now we're both lost
I've had a Gen 3 since 2006. I usually get met with confusion at the trails, but anyone who sees it in action is left impressed. Not the simplest or easiest on maintenance, but hard to beat for value.
Toasty
*Updated this thread with supporting words for the photos, go ahead and check it out above.
Went wheeling for realz this time to see how they held up to more serious stuff, PA_JERO dented his roof and i broke the passenger front U-Joint. I kinda thought Spicer joints were going to be short lived with 35's but i didn't think that short! ?
Next up, RCV's...
IMG-20200209-WA0033.jpgIMG-20200208-WA0099.jpgIMG-20200208-WA0030.jpgIMG_20200211_084502_940.jpgIMG_20200209_140346_390.jpg
PacS14
Damn Toasty! You really push your rigs, and what I mean by that I wish I could have half your talent and rigs so that I could do the same lol
Toasty
Thanks! Just takes practice. I'm just an okay driver, guys like PA_JERO and Montypower have talent behind the wheel. Maybe I'll get there some day.
  • Like
Reactions: plh
dvdswan
Sweet build and action shots. Kudos for sure. I did a 3-link front and rear on mine and will never go back to leaf springs.
Toasty
iStan814
